Here are my measurements for the new V1.3 Pi Zero power and USB test pads. I'd love it if anyone else could verify or correct. I also think I made a small error with the vertical dimension for PP22 and PP23 (although we never saw a problem with the original 5 prototype boards).
Yeah luckily the pads are quite large so you can get away with it.
Hi thanks for making this, Been looking all over for something to cross reference. I have double checked your dimensions and you are right about the height of PP22 and PP23, I measure them a 1.9mm but don't think it would make all that much of a difference.
I think you may be correct. My method to measure these wasn't too precise. I have had a reliable connection using these dimensions for the Pi Platter. But when I examine the pads on a Pi that has been mounted on a Pi Platter it appears the dimple where the pogo pin contacted the pad is just off-center. Thanks.
