Pi V1.3 test pad dimensions
A project log for "Solar Pi Platter"
A Li-Ion charger for Solar or USB with PMIC/RTC, 5V boost converter and USB Hub that can run Linux for only $5 more!
dan-julioDan Julio 06/30/2016 at 17:513 Comments
Here are my measurements for the new V1.3 Pi Zero power and USB test pads. I'd love it if anyone else could verify or correct. I also think I made a small error with the vertical dimension for PP22 and PP23 (although we never saw a problem with the original 5 prototype boards).
facelessloser wrote 02/22/2018 at 10:55 point
Yeah luckily the pads are quite large so you can get away with it.
facelessloser wrote 02/17/2018 at 15:53 point
Hi thanks for making this, Been looking all over for something to cross reference. I have double checked your dimensions and you are right about the height of PP22 and PP23, I measure them a 1.9mm but don't think it would make all that much of a difference.
Dan Julio wrote 02/21/2018 at 19:11 point
I think you may be correct.  My method to measure these wasn't too precise.  I have had a reliable connection using these dimensions for the Pi Platter.  But when I examine the pads on a Pi that has been mounted on a Pi Platter it appears the dimple where the pogo pin contacted the pad is just off-center.  Thanks.
