Ok, obviously you have to double check everything, when you order parts at Conrad Electronics.
Instead of 2.7k smd resistors they delivered 200k, so therefore the voltage coming out of the LM317 was way off.
Bodged it now by soldering a 2.7k through hole resistor in place.
