When leds are not enough
A project log for ScopeIO
Embedded Measurement System for FPGA
miguel-angelMiguel Angel • 05/11/2023 at 17:09•0 Comments
Display testpoint values on screen. It helped me to find deadlock bug on the UDP comm system.
https://discord.gg/66M5QX4
Project files  can be found on
https://github.com/hdl4fpga/hdl4fpga/tree/2a0e459e2c5e06b068ccb8dec8f681b24327e238
library/basic/base.vhd
library/basic/dpram.vhd
library/video/videopkg.vhd
library/video/tmds_encoder.vhd
library/video/cgafonts.vhd
library/video/cga_rom.vhd
library/video/cga_adapter.vhd
library/video/fonts/bcdfonts.vhd
library/video/fonts/cp850x8x8x0to127.vhd
library/video/fonts/cp850x8x8x128to255.vhd
library/video/fonts/cp850x8x16x0to127.vhd
library/video/fonts/cp850x8x16x128to255.vhd
library/basic/latency.vhd
library/basic/rom.vhd
library/video/video.vhd
library/video/dvi.vhd
library/basic/serlzr.vhd
library/basic/barrel.vhd
library/sdram/phy_iofifo.vhd
library/apps/app_profiles.vhd
library/apps/ecp5_profiles.vhd
library/apps/ecp5_videopll.vhd
library/basic/fifo.vhd
library/basic/sync_transfer.vhd
library/basic/adder.vhd
library/basic/txn_buffer.vhd
library/apps/display_tp.vhd
Example of usage
library ieee;
use ieee.std_logic_1164.all;
entity ulx3s is
    generic (
        debug : boolean := false);
    port (
        clk_25mhz      : in    std_logic;
        ftdi_rxd       : out   std_logic;
        ftdi_txd       : in    std_logic := 'U';
        ftdi_nrts      : inout std_logic := 'U';
        ftdi_ndtr      : inout std_logic := 'U';
        ftdi_txden     : inout std_logic := 'U';
        btn_pwr_n      : in  std_logic := 'U';
        fire1          : in  std_logic := 'U';
        fire2          : in  std_logic := 'U';
        up             : in  std_logic := 'U';
        down           : in  std_logic := 'U';
        left           : in  std_logic := 'U';
        right          : in  std_logic := 'U';
        led            : out std_logic_vector(8-1 downto 0);
        sw             : in    std_logic_vector(4-1 downto 0) := (others => 'U');
        oled_clk       : out   std_logic;
        oled_mosi      : out   std_logic;
        oled_dc        : out   std_logic;
        oled_resn      : out   std_logic;
        oled_csn       : out   std_logic;
        --flash_csn      : out   std_logic;
        --flash_clk      : out   std_logic;
        --flash_mosi     : out   std_logic;
        --flash_miso     : in    std_logic;
        --flash_holdn    : out   std_logic;
        --flash_wpn      : out   std_logic;
        sd_clk         : in    std_logic := '-';
        sd_cmd         : out   std_logic; -- sd_cmd=MOSI (out)
        sd_d           : inout std_logic_vector(4-1 downto 0) := (others => 'U'); -- sd_d(0)=MISO (in), sd_d(3)=CSn (out)
        sd_wp          : in    std_logic := '-';
        sd_cdn         : in    std_logic := '-'; -- card detect not connected
        adc_csn        : out   std_logic;
        adc_mosi       : out   std_logic;
        adc_miso       : in    std_logic := '-';
        adc_sclk       : out   std_logic;
        audio_l        : out   std_logic_vector(4-1 downto 0);
        audio_r        : out   std_logic_vector(4-1 downto 0);
        audio_v        : out   std_logic_vector(4-1 downto 0);
        wifi_en        : out   std_logic := '1'; -- '0' disables ESP32
        wifi_rxd       : out   std_logic;
        wifi_txd       : in    std_logic := '-';
        wifi_gpio0     : out   std_logic := '1'; -- '0' requests ESP32 to upload "passthru" bitstream
        wifi_gpio5     : inout std_logic := '-';
        wifi_gpio16    : inout std_logic := '-';
        wifi_gpio17    : inout std_logic := '-';
        ant_433mhz     : out   std_logic;
        usb_fpga_dp    : inout std_logic := 'U';
        usb_fpga_dn    : inout std_logic := 'U';
        usb_fpga_bd_dp : inout std_logic := 'U';
        usb_fpga_bd_dn : inout std_logic := 'U';
        usb_fpga_pu_dp : inout std_logic := 'U';
        usb_fpga_pu_dn : inout std_logic := 'U';
        sdram_clk      : inout std_logic;
        sdram_cke      : out   std_logic;
        sdram_csn      : out   std_logic;
        sdram_wen      : out   std_logic;
        sdram_rasn     : out   std_logic;
        sdram_casn     : out   std_logic;
        sdram_a        : out   std_logic_vector(13-1 downto 0);
        sdram_ba       : out   std_logic_vector(2-1 downto 0);
        sdram_dqm      : inout std_logic_vector(2-1 downto 0) := (others => 'U');
        sdram_d        : inout std_logic_vector(16-1 downto 0) := (others => 'U');
        gpdi_d         : out   std_logic_vector(4-1 downto 0);
        gpdi_dn        : out   std_logic_vector(4-1 downto 0);
        gpdi_cec       : inout std_logic := '-';
        gpdi_sda       : inout std_logic := '-';
        gpdi_scl       : inout std_logic := '-';
        gp             : inout std_logic_vector(28-1 downto 0) := (others => 'Z');
        gn             : inout std_logic_vector(28-1 downto 0) := (others => 'Z');
        gp_i           : in    std_logic_vector(12 downto 9);
        user_programn  : out   std_logic := '1'; -- '0' loads next bitstream from SPI FLASH (e.g. bootloader)
        shutdown       : out   std_logic := '0'); -- '1' power off the board, 10uA sleep
    alias rmii_tx_en   : std_logic is gn(10);
    alias rmii_tx0     : std_logic is gp(10);
    alias rmii_tx1     : std_logic is gn(9);
    alias rmii_rx0     : std_logic is gn(11);
    alias rmii_rx1     : std_logic is gp(11);
    alias rmii_crsdv   : std_logic is gp(12);
    alias rmii_nintclk : std_logic is gn(12);
    alias rmii_mdio    : std_logic is gn(13);
    alias rmii_mdc     : std_logic is gp(13);
    alias hdmi0_blue   : std_logic is gpdi_d(0);
    alias hdmi0_green  : std_logic is gpdi_d(1);
    alias hdmi0_red    : std_logic is gpdi_d(2);
    alias hdmi0_clock  : std_logic is gpdi_d(3);
    constant clk25mhz_freq : real := 25.0e6;
end;
library ieee;
use ieee.numeric_std.all;
library hdl4fpga;
use hdl4fpga.base.all;
use hdl4fpga.videopkg.all;
use hdl4fpga.ipoepkg.all;
use hdl4fpga.app_profiles.all;
use hdl4fpga.ecp5_profiles.all;
library ecp5u;
use ecp5u.components.all;
architecture display_tp of ulx3s is
    constant video_mode  : video_modes := mode600p24bpp;
    constant video_param : video_record := videoparam(video_mode);
    signal video_pixel   : std_logic_vector(0 to setif(
        video_param.pixel=rgb565, 16, setif(
        video_param.pixel=rgb888, 32, 0))-1);
    signal sys_rst         : std_logic;
    signal sys_clk         : std_logic;
    signal videoio_clk     : std_logic;
    signal video_clk       : std_logic;
    signal video_shift_clk : std_logic;
    signal video_lck       : std_logic;
    signal video_hzsync    : std_logic;
    signal video_vtsync    : std_logic;
    signal dvid_crgb       : std_logic_vector(7 downto 0);
    signal tp              : std_logic_vector(0 to 6-1);
begin
    sys_rst <= '0';
    videopll_e : entity hdl4fpga.ecp5_videopll
    generic map (
        clkref_freq  => clk25mhz_freq,
        default_gear => 2,
        video_param  => video_param)
    port map (
        clk_ref     => clk_25mhz,
        videoio_clk => videoio_clk,
        video_clk   => video_clk,
        video_shift_clk => video_shift_clk,
        video_lck   => video_lck);
    tp <= (fire1, fire2, up, down, left, right);
    displaytp_e : entity hdl4fpga.display_tp
    generic map (
        timing_id    => video_param.timing,
        video_gear   => 2,
        num_of_cols  => 1,
        field_widths => (15,10,3),
        labels     =>
            "fire1" & NUL &
            "fire2" & NUL &
            "up"    & NUL &
            "down"  & NUL &
            "left"  & NUL &
            "right" & NUL)
    port map (
        sweep_clk   => video_clk,
        tp          => tp,
        video_hs    => video_hzsync,
        video_vs    => video_vtsync,
        video_pixel => video_pixel,
        dvid_crgb   => dvid_crgb);
    ddr_g : for i in gpdi_d'range generate
        signal q : std_logic;
    begin
        oddr_i : oddrx1f
        port map(
            sclk => video_shift_clk,
            rst  => '0',
            d0   => dvid_crgb(2*i),
            d1   => dvid_crgb(2*i+1),
            q    => q);
        olvds_i : olvds
        port map(
            a  => q,
            z  => gpdi_d(i),
            zn => gpdi_dn(i));
    end generate;
end;
