Hackaday.io Hackaday.io
Sign up Log in
Tri-omni wheel Pi Zero robot
Platform to run tri-omni wheel configuration with Raspberry Pi and hobby ESCs
jeffrey-jacquesJeffrey Jacques
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.6k views
0 comments
23 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 14
    • View all
  • Logs 3
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
1.6k
0
23
8
Team (1)
  • jeffrey-jacquesJeffrey Jacques
Join this project's team
MISC
ongoing project
KIWI raspberry pi pi zero omni wheel ROBOT
Related lists
Raspberry Pi Projects
Projects based on everyone's favorite low cost Linux Machine - The Raspberry Pi
This project was created on 02/27/2016 and last updated 11 years ago.
Description
Acrylic base with 6v DC gear motors arranged in 120° tri-omni wheel configuration with Raspberry Pi Zero and Hobbywing Quickrun 1060 ESCs.
Files
chassis.skp
SSEYO Koan Play File - 111.21 kB - 02/27/2016 at 16:44
Download
Components
  • 3 × 25mm ebay gear motor bracket
  • 3 × GA25Y370-47 6V DC 125 RPM gear motor
  • 3 × 4mm to 5mm Set Screw Shaft Coupler Actobotics Part # 625218 5mm shaft side tapped to 6mmx1
  • 1 × Rapberry Pi Zero
  • 3 × 38mm (1.5inch) double plastic omni wheel
View all 14 components
Project Logs
Collapse
  • DS4 Linux driver bug
    Jeffrey Jacques • 03/16/2016 at 19:22 • 0 comments
    At the time of writing, Raspian is running Linux kernel 4.1.19 that has a bug in the bluetooth driver for Sony DualShock 4 controllers with newer firmware. Kernels as of 4.5rc1 have the fix. Until Raspian kernel packages catch up the solutions I can see are to backport this fix by patching and compiling a custom 4.1.x kernel or just running a DS4 of an older firmware.
    Info on the driver fix is here:
    https://git.kernel.org/cgit/linux/kernel/git/jikos/hid.git/commit/?h=for-4.5/sony&id=b71b5578a84d297954e4812ba0ca2d466e61cf42
    Kernel Building on Raspberry Pi:
    https://www.raspberrypi.org/documentation/linux/kernel/building.md
  • Dynamite ESC quick fix
    Jeffrey Jacques • 03/03/2016 at 15:48 • 0 comments
    Was able to scavenge a Dynamite WP 60A ESC (DYNS2210) that came with the Vaterra Ascender RTR. Virtually the same specs and size, likely a just re-branded Hobbywing. Back together and running!
  • ESC woes
    Jeffrey Jacques • 03/01/2016 at 22:05 • 0 comments
    So one of the Hobbywing ESCs is defective and will need replacing. It only runs for a few seconds then dies. The fact that only the defective one has a distinct high pitch whine when powerd was a clue.The other issue is that the reverse mode is less power and thus spins slower per pulse. Maybe this can be compensated for in software, but I'm not sure the rate is proportional. Would be a bummer to have scrap these and go with more expensive ones.
View all 3 project logs
Log In/Sign up to comment
Sign up with Github
OR
UART GPS Module, supports GPS, BDS and QZSS. Can be plugged to Raspberry Pi directly.
Project Owner Contributor
Ultimate GPS HAT for Raspberry Pi Series
undefined
How to play Counter Strike and Diablo II on Raspberry Pi
New Era of Gaming on Raspberry Pi
dmitryDmitry
Connecting Raspberry Pi HATs Wirelessly with PiSquare Launching on Kickstarter
£9 PiSquare Can Connect Multiple HATs Wirelessly
undefined
The default speed of the Raspberry Pi Zero 2 W is 1GHz. The speed may be increased to 1.2GHz or even 1.4GHz.
Overclocking the Raspberry Pi Zero 2 W to 1.4 GHz
undefined
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Tri-omni wheel Pi Zero robot", please tell us the reason.
Send message
Remove Member
