Refactorization using new technology.
I have recently acquired and learned how to use (to some degree of success) a Prusa i3 Rep-Rap printer so I have been working on making something similar to my other builds except actually wearable. This is a more "modern" implementation... take that however you like I just say it because bluetooth 4.0 is a pretty recent technology.
Some interesting things to note:
- Design had 3d printing in mind from the start
- This lead to a semi-permanent modular system.
- The cable routing was included in each section as well.
- I had decided on a 3 part system and used threaded rod for fastening
- Lots of documentation on this technology was available (thanks to all the super awesome pioneers {three links there} in this field)
- I had seen a large amount (about 3) of other keyer builds that used these switches
- I wanted to circle back to this project after I had some skills under my belt
- (3d printing/printer, Soldering, Arduino)
- My previous attempts at this technology were hindered by my lack of skills and a 3d printer.
