FT_PROG template.xml
since the FT2232H has a configuration EEPROM attached, these settings can be written with the FT_PROG tool to initialize the USB device and set all values accordingly. Since it targets mainly non-UART applications, the VCP drivers are deactivated. This can be changed back easily with FT_PROG.
XML - Extensible Markup Language -
4.29 kB -
02/27/2016 at 21:12
