As an embedded engineer, I like schematic, layout, coding, debugging. I also except to understand various concepts of OS, for example, task, semaphore, message queue, scheduling, etc.
So OSCUS is coming. It's a hackable OS for hardware hobbyists. It's neat and tiny.
The code line is about 1K and just need a little amount of RAM about 100bytes to run.
So it is very easy to understand and use for those who are interesting in OS concept.
It features:
- Co-operative multitasking, without complex stack management
- Two-level scheduling mechanics, priority-based(maximum eq 0x04)
- and round-robin in each priority level(maximum eq 0x04)
- Maximum task number eq 16
- Rapid task switch, time complexity O(1)
Task Model:
- Task priority ranges from 0x00 to 0x0F
- When there are no tasks in the higher priority level group, controller will be give to tasks in the lower priority
- When two or more tasks have the same priority, controller will be given to the next after the previous run-to-completion
- Task 0 as idle routine, must be defined
** Round-robin scheduling in each group
** | F | E | D | C | - priority level 3 - highest | Priority-based
** | B | A | 9 | 8 | - priority level 2 V scheduling
** | 7 | 6 | 5 | 4 | - priority level 1
** | 3 | 2 | 1 | 0 | - priority level 0 - lowest
Here is the schedule lookup table and routine for 4x4 tasks.
First we search the highest priority group, then each ready-to-run task in the group will be invoked round by round.
So we can implement the schedule time complexity O(1).
crByte const crDskTbl[][CR_RR_PPL_NUM]={
0x00,0x00,0x00,0x00, /*0:0000*/
0x00,0x00,0x00,0x00, /*1:0001*/
0x01,0x01,0x01,0x01, /*2:0010*/
0x01,0x00,0x01,0x01, /*3:0011*/
0x02,0x02,0x02,0x02, /*4:0100*/
0x02,0x00,0x00,0x02, /*5:0101*/
0x02,0x02,0x01,0x02, /*6:0110*/
0x02,0x00,0x01,0x02, /*7:0111*/
0x03,0x03,0x03,0x03, /*8:1000*/
0x03,0x00,0x00,0x00, /*9:1001*/
0x03,0x03,0x01,0x01, /*A:1010*/
0x03,0x00,0x01,0x01, /*B:1011*/
0x03,0x03,0x03,0x02, /*C:1100*/
0x03,0x00,0x00,0x02, /*D:1101*/
0x03,0x03,0x01,0x02, /*E:1110*/
0x03,0x00,0x01,0x02};/*F:1111*/
void crTaskSched()
crByte BitX,BitY;
//crAssert("crTskSched begin:0x%02x\r\n", crRdyTskGrp != 0x00);
BitY = CR_DBIT_FSB(crRdyTskGrp);
BitX = CR_DBIT_NXT(crRdyTskRow[BitY], crRdyTskCol[BitY]);
crRdyTskCol[BitY] = BitX;
crRdyTskIdx = CR_BIT_OR(CR_BIT_LSHIFT(BitY,2), BitX);
//crAssert("crTskSched end:%d\r\n", crTskTbl[crRdyTskIdx].entry != (void*)0x00...
gokux
surfingsteve
Gee Bartlett
Hi bobricius,
OSCUS supports max 4*4 tasks and two-level scheduling mechanics, priority-based and round-robin.
So the 4 rows of the led matrix represent the priority level, and the 4 columns represent the round-robin tasks in each priority level.
Through the led state of the matrix, we will easily understand show the OS works, including task execution, scheduling, semaphore, message, etc. :)
