Try before you buy!!
A project log for TinyPi Advance
The next stage of the TinyPi Story
mooseprmoosepr 03/26/2018 at 22:004 Comments
The board design was pretty much nailed, I just added a touch more design flourish and then it was done
The boards were made by @oshpark and as usual came back flawless
so i fired up the soldering iron, and while i was waiting, just had a look at how it all fitted together, and oh no!!
I did not check where those ports were!! As this is just an early prototype i carried on and made it work. Trimmed some of the usb socket metal and things just about went together.
although nobody is using that usb port!!
It just goes to show that you should always check your designs before you splash the cash!! At lest it went together ok ;)
Rich text editor
deʃhipu wrote 03/27/2018 at 07:35 point
That actually doesn't look as bad as I feared. I suppose you could have printed the design on paper and tried it.
moosepr wrote 03/27/2018 at 07:59 point
yeah i need to get better at that O:-)
davedarko wrote 03/26/2018 at 22:34 point
I'm still waiting for that shiny tiny display update :p
im playing catchup :P
