1Step 1
The linear stage:
Dimensions: 35x35x13 mm
Translational range: ±4 mm
Precision: M3 screws has a pitch of 0.5 mm, so 1/8th of a turn corresponds to 0.0625 mm of translation.
Parts:
- 40mm M3 screw
- 4 M3 hexnuts
- One bicycle spoke
- Two springs from ballpoint pens
Print the top and bottom parts. Melt the two inner hexnuts into the plastic:
Cut the two springs in half (or other suitable size). Cut the bike spoke (so it's sharp) and assemble everything.
The linear stage shouldn't exhibit any free play.
2Step 2
2. The square kinematic mirror mount
Mirror dimensions are 18x26mm
Download the file.
Additional components are:
- 1 steel ball bearing (Ø = 4mm)
- 2 tension springs ()
- 2 M3 dome nuts
- 4 M2 screws (or possibly M1.5 - I don't remember)
- 2 M3 12mm screws, 4 M3 hexnuts
- 1 paper clip (to attach the springs)
Print the 3 parts and assemble. It should look like this:
esben rossel
