PRML
A project log for anaQuad!
Reliably increase your quadrature-encoder's resolution using an ADC (or a bunch of comparators?)
eric-hertzEric Hertz • 09/23/2018 at 03:09•1 Comment
hmmm....
http://www.pcguide.com/ref/hdd/geom/dataPRML-c.html
So, hard disks now use ADCs and DSPs to detect ones and zeros...
This looks like a job for ANAQUAD!
Is it too much to ask that two heads on opposite sides of the platter (or maybe two on the same?) stay perfectly-aligned over time and temperatures? 'Cause a rough estimate using anaQuad would easily double, plausibly even quadruple, the capacity despite using twice the physical space...
Thanks @Starhawk for sending me down that path, looking up ZIP drives' encoding-schemes!
Starhawk wrote 09/23/2018 at 05:08 • point
Oh, boy, I've created a monster, haven't I...?
...should I be cackling right now? Because I am.
