Polos CH32VXX RISC-V Breakout Boards
CH32V Series MCUs are designed by Qinheng Microelectronics Co., Ltd., focuses on connectivity technology and microprocessor research and is an IC design company. CH32V Series MCUs are low-cost & powerful functions like BT, USB2.0/3.0, CAN, I2C, SPI, USB PD and so on. So we develop the Polos CH32Vxx RISC-V Breakout Boards. Qinheng Provide C/C++ SDK, Arduino Library, and MRS IDE. We perfer to use Embedded Rust, We will support Embedded Rust development in CH32Vxx RISC-V MCU.
Polos CH32V003 Breakout Alef - Features
- Main Chip Type: CH32V003F4U6 with QFN20 Package
- QingKe 32-bit RISC-V2A processor, Up to 48MHz frequency
- 2KB SRAM, 16KB Flash, 3.3/5V Power Supply
- 1 ch DMA, 1 group of OP Amp, 1 group of 10-bit ADC
- 16 bit timer x 2
- USARTx1, I2Cx1, SPIx1
- 18 I/O ports, mapping an external interrupt
- 64-bit chip unique ID
- 1-wire serial debug interface (SDI)
Polos CH32V203F8 Breakout Alef - Features
- Main Chip Type: CH32V203F8P6 with TSSOP20 Package
- Qingke V4B, up to 144MHz frequency
- 20KB SRAM, 64KB Flash, 3.3/2.5V Power Supply
- Low-power modes: sleep/stop/standby
- Down to 44.65uA/MHz in Run mode
- Down to 17.90uA/MHz in Sleep mode
- 1 x 18ch DMA, 2xOP Amps, 2 x 9ch 12-bit ADC
- 1xUSB2.0 FS H/D
- USARTx2, I2Cx1, SPIx1
- 17 I/O ports, mapping 16 external interrupt
- CRC calculation unit, 96-bit unique ID
- Serial 2-wire debug interface
Polos CH32V305 Breakout Alef - Feautres
- Main Chip Type: CH32V305FBP6 with TSSOP20 Package
- Qingke V4F, up to 144MHz frequency
- 32KB SRAM, 128KB Flash, 3.3/2.5V Power Supply
- 2 x 9ch DMA, 1x12 bit DAC, 2 x 1ch 12-bit ADC
- 1xUSB2.0 HS H/D
- CANx1
- Timerx8
- Touch Key x1
