COLOR Barcode
mit41301mit41301 wrote 01/25/2026 at 15:59 • • 2 min read • Like
High Capacity Color Barcodes (HCCB) and JAB Code are advanced 2D barcode technologies that use multiple colors to significantly increase data storage density compared to traditional black-and-white codes.
HCCB Technology Developed by Microsoft Research, HCCB uses multicolor symbols and unique shapes to store more data per square inch. Laboratory tests have shown storage of up to 2,000 bytes or 3,500 characters per square inch at 600 dpi — roughly equivalent to two pages of a novel. It supports digital signing using Elliptic Curve Cryptography (ECC) with RSA-1024 equivalent security, enabling data integrity verification. HCCB can store multiple payloads in a small file system format and is optimized for mobile device decoding, even from low-quality images, outperforming QR Codes in some scenarios.
JAB Code JAB Code (Just Another Barcode) is an ISO/IEC 23634:2022 standard for high-capacity color barcodes. It uses colorful square modules arranged in grids, with a primary symbol (containing finder patterns) and optional secondary symbols for scalability. It supports error correction and can encode from small to very large datasets. JAB Code is open-source, with a C-based library for encoding/decoding, and can be built for Linux or Windows.
JABCODE
jabcode/jabcode: jabcode - color bar code
JAB Code Standard ISO/IEC 23634
The following sequence of Pi is encoded into JABCODE as follows:
3.14159265358979323846264338327950288419716939937510582097494459230781640628620899862803482534211706798214808651328230664709384460955058223172535940812848111745028410270193852110555964462294895493038196442881097566593344612847564823378678316527120190914564856692346034861045432664821339360726024914127372458700660631558817488152092096282925409171536436789259036001133053054882046652138414695194151160943305727036575959195309218611738193261179310511854807446237996274956735188575272489122793818301194912983367336244065664308602139494639522473719070217986094370277053921717629317675238467481846766940513200056812714526356082778577134275778960917363717872146844090122495343014654958537105079227968925892354201995611212902196086403441815981362977477130996051870721134999999
Online barcode generator ULTRACODE
Ultracode:
This Symbology is also known as Ultracode 2D Color Barcode a.k.a AIM ISS Ultracode.
The Ultracode symbology is a colour, 2D matrix-style barcode symbology that can encode full 256 character extended-ASCII. It supports six error correction levels.
Example of Ultracode barcode images
Code property = Lorem ipsum dolor sit amet, consectetur adipiscing elit. will produce the following barcode image:
Free Online Barcode Generator - Create Print-Ready Barcodes
ultracode
250 digits of Pi
Like
