The AI hardware conversation usually starts with accelerators, memory bandwidth, and networking. At the board level, however, every watt still becomes a power-conversion and thermal-design problem. As racks become denser, the supporting components are becoming just as important as the processor.
Why higher-voltage distribution is attractive
Delivering the same power at a higher voltage reduces current. Lower current can reduce conductor loss, copper cross-section, connector stress, and the number of parallel paths. Recent industry work is exploring 800 VDC distribution for next-generation AI infrastructure; Wolfspeed has described 1200 V SiC MOSFETs as an enabling device for high-voltage conversion in that architecture.
That does not mean every server should immediately jump to 800 V. It means the power tree is being reconsidered: higher-voltage distribution, isolated conversion, intermediate bus stages, point-of-load regulators, and a lot of sensing and protection. Each stage has a different sweet spot for silicon, SiC, or GaN.
Where the component choices matter
At lower voltage and high frequency, silicon MOSFETs remain extremely capable and cost-effective. GaN can be attractive when switching loss and frequency are dominant. SiC is especially useful when blocking voltage, temperature, ruggedness, and high-power conversion matter. The correct choice depends on topology, switching frequency, gate-drive behavior, thermal path, and operating profile—not on a material label alone.
The first bench measurements should include more than efficiency. Check the gate waveform at the actual power-loop inductance, ringing at the switch node, current sharing between parallel devices, magnetics temperature, and capacitor ripple current. A converter can show good average efficiency while still producing damaging overshoot or a hot local component.
Layout is part of the power semiconductor
A fast switch and a poor layout make a fragile system. Keep the high-di/dt loop compact, use a low-inductance gate-return path, place ceramic bypass capacitors close to the switching devices, and provide a defined return path for control signals. At higher voltage, clearance, creepage, insulation, and probe technique become safety requirements rather than cosmetic details.
For early architecture work, DC-DC converter options can help organize the voltage-conversion stages before specific part numbers are selected. For a thermal hotspot on a compact power board, metal-core PCB construction may be worth evaluating alongside a conventional FR-4 board with thermal vias.
The application is also useful for sourcing decisions. Octatronics groups power, energy, automotive, data-center, and industrial requirements in its application guide, which is a better starting point than choosing a device from a generic voltage filter.
A simple validation sequence
- Estimate conduction and switching losses at minimum and maximum input voltage.
- Select a tentative switch, gate driver, inductor, and capacitor network.
- Simulate the switching node and gate loop, including package and layout parasitics.
- Build a low-energy prototype with current limiting and a safe probing plan.
- Measure overshoot, ringing, temperature rise, and transient response.
- Only then scale the power and lock the PCB stackup, thermal interface, and production test points.
The AI power wall is not solved by buying a more advanced transistor. It is solved by coordinating semiconductor selection, magnetics, protection, thermal design, PCB geometry, and measurement discipline.
AlexMo
