How to Read a MOSFET Datasheet for a Switching Converter
alexmoAlexMo wrote 2 days ago • 3 min read • Like
Choosing a MOSFET by voltage, current, and low RDS(on) is a quick way to get the wrong device. Those three numbers are useful, but a switching converter cares about several values that are easy to overlook: gate charge, output capacitance, reverse-recovery behavior, thermal resistance, and how the ratings change with temperature.
This guide presents a practical reading order for a buck or boost converter.
1. Confirm the voltage margin
Start with the drain-source voltage, but do not stop at the nominal bus voltage. The device must survive the converter’s switching overshoot, ringing, startup condition, load dump, and any externally coupled transient.
If a 24 V rail produces a 10 V overshoot at the switch node, a 30 V MOSFET has almost no useful margin even though its headline rating appears sufficient. Capture the real waveform with a short probe connection and include tolerance in the worst-case estimate.
The MOSFET selection reference at MOZ Electronics can help organize the initial search by device type. The final voltage choice still depends on the converter topology, clamping strategy, layout, and transient test.
2. Use the right RDS(on) value
Datasheets commonly quote RDS(on) at a particular gate-source voltage and at 25 °C. A logic-level device may be specified at 4.5 V or 2.5 V, while a power device may assume 10 V gate drive. Compare the value at the gate voltage your driver actually provides.
Conduction loss is approximately:
Pcond = Irms² × RDS(on)
The resistance increases with junction temperature, so the 25 °C figure is optimistic. Use the temperature curve or a conservative multiplier when estimating loss. In a synchronous buck, calculate conduction loss for both high-side and low-side devices using their actual RMS current waveforms.
3. Read gate charge as a switching specification
Total gate charge Qg is not the same as input capacitance, and it is not a universal speed rating. It depends on drain voltage, gate voltage, and test conditions. The Miller plateau charge is especially important because it represents the charge needed while the drain voltage is changing.
A rough gate-drive loss estimate is:
Pgate ≈ Qg × Vdrive × fs
This loss is dissipated mostly in the driver, not the MOSFET, but a high Qg can demand more driver current and slow the transition. Slower edges increase overlap loss; faster edges can increase ringing and EMI. The right choice is a system trade-off, not the smallest Qg in a search table.
4. Check switching loss and Coss
For a first estimate, switching overlap loss can be approximated as:
Psw ≈ 0.5 × VDS × ID × (tr + tf) × fs
The equation is only a starting point because the actual waveform depends on the driver, gate resistor, parasitics, load current, and diode behavior. Coss also matters. The energy stored in the output capacitance is not always well represented by a single capacitance value, especially at high drain voltage.
For hard-switched converters, review the Coss energy curve, reverse-recovery specification of the body diode, and dead-time behavior. For soft-switching topologies, the relevant trade-offs may be different.
5. Treat thermal ratings as design inputs
The datasheet’s maximum junction temperature is a limit, not a target. Estimate junction temperature from the measured or calculated device loss and the real thermal path. Package type, exposed pad soldering, copper area, vias, airflow, and neighboring hot parts all affect the result.
A component derating calculator provides a quick first-pass check for voltage, current, or power margin. Use the result to identify weak assumptions, then verify the actual MOSFET curves and board temperature with a thermocouple or thermal camera.
6. Validate the footprint and assembly path
A low-loss MOSFET can become a high-loss assembly if the exposed pad is poorly soldered, the land pattern is wrong, or the stencil leaves voids in the thermal area. Check the manufacturer’s recommended footprint and inspection method. SMT assembly guidance is useful when the design uses QFNs, power DFNs, or other packages whose thermal connection is hidden below the part.
A compact selection checklist
Finally, record why the device was chosen. Octatronics’ technical resources can be useful when comparing the component decision with the application’s power, thermal, and lifecycle requirements. A MOSFET is not selected in isolation; it is selected as part of a waveform and a manufacturing process.
Like
