What is LoRa Network?
09/15/2025 at 12:53 • 0 commentsAre you looking for a cheap wireless solution? Maybe LoRa is right for you. It stands for Long Range, and is a patented digital wireless data communication technology. It's a type of low-power wide-area network (LPWAN) modulation technique that operates on unlicensed sub-gigahertz radio frequency bands. LoRa is known for its ability to transmit data over long distances with minimal power consumption, making it ideal for battery-powered devices in Internet of Things (IoT) applications. 📡
Meshtastic is an open-source project that allows you to create your own off-grid, long-range communication network. It uses inexpensive, low-power LoRa (Long Range) radios to send text messages and GPS data without the need for Wi-Fi, cell service, or satellites.
I have used LoRa for a refrigelator temperature sensor. The problem with this sensor is that the battery life is only last for 2 months.
How does RISC-V works?
09/12/2025 at 19:14 • 0 commentsAre you a hardcore programmer? Then implementing a RISC-V processor on an FPGA is right for you. It involves using the programmable logic to create a "soft core" of a RISC-V CPU. Instead of using a fixed, off-the-shelf processor, designers can instantiate a RISC-V core, available as hardware description language code like Verilog or VHDL, within the FPGA.
The existing FPGA implementations are:
- RISC-V CPU: https://github.com/lnis-uofu/OpenFPGA
- Java VM: https://github.com/amal029/jop
We can implement GPU on FPGA, it can be effectively used for the custom hardware accelerators for graphics processing, offering advantages in low latency, and integration for specific applications.
How to build a 3D Printer?
09/11/2025 at 08:52 • 0 commentsAre you a 3D designer? Then a 3D printer is right tool for you. It is a machine that uses additive manufacturing to create three-dimensional objects from a digital design. Essentially, it builds an object by depositing plastic filament layer by layer. I have made a Ramp 1.4 schild for Arduino Due. See the KiCad design here: https://gl.tetra.nl/xuyi/niceramps
You have to be careful of the Fire Safety issues of a 3D Printers. A SCARA robot (Selective Compliance Assembly Robot Arm or Selective Compliance Articulated Robot Arm) is a type of industrial robot known for its high speed, precision, and application in assembly and pick-and-place operations.
