Thermal Design Lessons From DIY High-Power Lighting
03/05/2026 at 16:05 • 0 commentsHigh-power LED lighting looks deceptively simple from the outside. You attach a powerful LED to a heatsink, add airflow, and the system should run within thermal limits.
In practice, things rarely behave that cleanly.
While developing several experimental high-power LED systems, I ran into a number of thermal issues that don’t always show up in datasheets or simplified calculations. Small mechanical details often ended up having a larger impact than expected.
Heat density becomes the real problem
Once LED power levels move into the hundreds of watts, the main challenge is no longer electrical — it’s thermal density.
The LED die may only occupy a small surface area, but it must transfer a large amount of heat into the cooling system. Any imperfection along that thermal path increases junction temperature.
Even small changes in mounting conditions can make a measurable difference.
High-power LED module mounted to a custom cooling assembly
The interface layer matters more than expected
One of the most surprising lessons was how sensitive the system was to the thermal interface between components.
Things that seemed minor during design had real consequences during testing:
mounting pressure
surface flatness
thermal paste thickness
copper interface geometry
Changing only the mounting pressure between the LED module and the base plate could noticeably affect steady-state temperature.
Copper interface plate used to improve heat transfer between LED module and radiator.Airflow is rarely what you think it is
Another lesson came from airflow.
Initial cooling designs assumed fairly predictable air paths through the radiator. In reality, airflow tends to follow the path of least resistance, which sometimes bypasses the areas that need cooling most.
This meant that fan placement and radiator geometry became just as important as raw heatsink mass.
Large radiator assembly with multiple fans used for high-power LED cooling
Iteration is unavoidable
Thermal design at these power levels is difficult to solve perfectly on paper.
In practice, each prototype revealed small details that needed adjustment:
mechanical tolerances
airflow distribution
contact surfaces
mounting hardware
Several iterations were required before the system reached stable operating temperatures.
Final thoughts
High-power LED systems are often presented as straightforward engineering problems, but real-world builds quickly reveal how sensitive they are to mechanical and thermal details.
For anyone experimenting with high-power lighting, the biggest lesson may be this:
Thermal design is not just about the heatsink — it’s about the entire path the heat must travel.
Project website: https://ledchip.pro/
Project Instagram: https://lnkd.in/gwwPBieE
Personal Instagram: https://lnkd.in/gUpA3xHm -
Custom Radiator Design for Extreme LED Power
02/27/2026 at 13:46 • 0 commentsHigh-power LEDs are easy to drive electrically.
Keeping them alive at extreme power density is a different story.
When I started pushing beyond moderate LED power levels, standard aluminum heatsinks stopped being enough. Not because they were small — but because heat density, mounting geometry, and long-term thermal stability introduced constraints that off-the-shelf radiators weren’t designed for.
This led to a custom radiator design.
Why Standard Heatsinks Failed
At lower power levels (≈200–300W), a large extruded aluminum heatsink with proper airflow was sufficient.
Once total power and density increased, several issues appeared:
Uneven temperature distribution across the board
Localized hot zones
Mounting pressure sensitivity
Mechanical flex affecting thermal contact
Airflow dead zones
The issue wasn’t just “more heat.”
It was how heat moved through the structure.Early mounting tests revealed uneven temperature spread across the array.
The Design Constraints
The custom radiator had to solve several problems simultaneously:
High thermal conductivity at the LED interface
Even pressure distribution across a large board
Structural rigidity under clamping force
Controlled airflow channels
Long-term stability under sustained load
Instead of simply increasing aluminum mass, I redesigned the thermal path.
Copper vs Aluminum
Aluminum is practical and affordable.
Copper conducts heat significantly better.For extreme density applications, the solution became hybrid:
Copper interface section for fast heat spreading
Aluminum bulk structure for mass and cost control
Controlled transition between materials
The key wasn’t just conductivity — it was reducing thermal bottlenecks at the interface.
Copper interface plate improves initial heat spreading before transfer into the main aluminum mass.
Mechanical-Thermal Coupling
One unexpected factor: structural rigidity.
At high clamping forces, minor flex in the mounting structure altered contact pressure. That changed thermal resistance.
The radiator became not just a heat sink — but a mechanical component.
Increasing stiffness improved temperature uniformity more than simply enlarging fin area.
Airflow Reality vs Assumptions
Simulations and intuition often assume clean airflow paths.
In reality:
Fans introduce turbulence
Fins create dead zones
Adjacent structures disrupt flow
Custom airflow channeling was required to ensure consistent cooling across the entire surface.
Airflow path optimization proved as critical as raw heatsink mass.
The Result
With the redesigned radiator:
Temperature distribution became more uniform
Junction temperature dropped under sustained load
Long-term stability improved
Degradation rate decreased
The solution wasn’t larger.
It was more controlled.Final Thought
At extreme LED power levels, a radiator isn’t just a chunk of metal.
It’s a thermal system that must integrate:
Materials science
Mechanical rigidity
Pressure control
Airflow engineering
And once you cross a certain power density threshold, off-the-shelf solutions simply aren’t designed for that regime.
