C214AA_XSBO_SCH.pdf
Schematics
Adobe Portable Document Format - 44.80 kB - 03/31/2016 at 11:20
Preview
C214A_XSBO_PCB.pdf
PCB Drawing
Adobe Portable Document Format - 137.16 kB - 03/31/2016 at 11:20
Preview
LPC81X_UM10601.pdf
LPC812 User Manual
Adobe Portable Document Format - 1.71 MB - 03/31/2016 at 11:08
Preview
LPC81XM.pdf
LPC812 Data Sheet
Adobe Portable Document Format - 734.18 kB - 03/31/2016 at 11:07
Preview
C214A_XSBO.GBR.ZIP
Gerber files - Compliant with Eurocircuits and PCBway pooling processes.
Zip Archive - 290.02 kB - 03/31/2016 at 11:06
Download
YASKarm_test_LPC812.hex
This hex file is a precompiled blinky test for the XSBO board.
It can be flashed thanks to an LPClink board or with FlashMagic.
This software produces a rather fast (2 Hz) heart beat on the board LED and toggles each available port 20 times per second. Keep in mind that P0_10 and P0_11 are open drain outputs. You will need pull-ups to see them toggle on your oscilloscope screen.
hex - 12.68 kB - 03/22/2016 at 14:27
Download
YASKarm_test_LPC812.c
Test program source file. Uses my YasK kernel. Just ask me if you want the complete package in order to recompile the program.
C Source File - 3.79 kB - 03/31/2016 at 11:09
Download
