Wee tiny update
05/06/2014 at 06:58 • 0 commentsI've added in build instructions for the wind version, I will add in alternate steps for the mouthpiece version later today. The Trombino is now able to send mapped OSC, unmapped OSC and MIDI information (via OSCulator) as well as outputting sound.
Where I'm at.
05/01/2014 at 16:58 • 0 commentsSo the Trombino is in the sort of advanced prototype stage at the moment. All the hardware has been settled on and works, I'm currently working on making sure the outputs are as useful as possible (for example currently the OSC data it outputs is in the format of mouth reading and note calculated from trombone like mappings, I'd also like to output the data without mappings and in MIDI form).
