files uploaded
03/22/2016 at 01:58 • 0 commentsUploaded board design and OSHPark submission files.
My Zero arrived today after being listed as "processing exception" status in New Your for several days. Sounds like something I'd encounter after running a wonky kernel module, not something involving shipping...
Board is ordered. I'll order parts in the next couple days.
I tested leakage from the inductive coupling. Magnetic shielding doesn't work, but a bit of aluminum tape should work, with only a little loading of the coil. The real test is to see if a Zero locks up when mounted. I've got my fingers crossed...
initial posting
03/13/2016 at 17:56 • 0 commentsInitial posting. I'm waiting for receipt of my Zero from Adafruit before proceeding with further assembly (it shipped today).
Base with motor has been assembled and tested. Inductive charger has been tested and works.
To Do: design circuit board and order, spec and order LEDs.
