3D CAD in progress.
07/12/2018 at 10:55 • 0 commentsI am currently doing the 3D CAD of the robot body.
For the moment, the robot has no caterpillars. I prefer to stay simple and use wheels for the first prototype.
Here is the right part :
I need to make some adjustments before printing the left part.I still have to do the central part (on which will come the electronics and the potato).
In the following days, I will try to update my github repository and add details to this project page.
It's (almost) working !
07/10/2018 at 21:06 • 0 commentsI didn't have potatoes at home, so let's build an Onion Robot for now !
The two supercapacitor are slowly charging (i didn't measure the current/voltage/energy but it's charging) and the undervoltage, overvoltage, good battery indicator work well but the 3V3 regulator can only power very small load when it's connected to the BQ25504.if i want power bigger load (the i2c motor driver for example), i have to connect the regulator input directly to the supercapacitors
I think the problem of power limitation comes from my layout. I will try to modify the board with tiny wires and fine soldering skill, until i make a version 2 of this board.
The i2c motor driver works perfectly well (μController, H-Bridges, and quad comparator).
I am currently working on the body of the robot (it will be printed in 3D). I hope to post some photos or pictures soon.
Soldering done !
07/05/2018 at 18:45 • 0 comments![]()
I just finished soldering the boards.
I made some mistakes but it was easily repaired.
I have not yet test everything, but the buck boost converter (energy harvesting module) and the quad comparator (motor driver module) is working properly.
Tomorrow, I will try to flash the microcontroller, and test the the H-Bridge ICs...
PCB and components finally here !!!
07/01/2018 at 19:56 • 0 comments![]()
Problem with the gerber files ??
06/07/2018 at 08:35 • 0 commentsI wanted to send PCB in production, but i have a problem with the gerber files of the harvesting module : The online gerber viewer (from JLCPCB) does not want it.
There is no problem with the other two modules, and i use the same export parameters.
I tried to export with another computer (and a different OS), but the problem persists.
I also tried to upload the files to another PCB manufacturer (EuroCircuit: we use this manufacturer at my job, but it's a lot more expensive than the Chinese manufacturer), and it works this time...
I don't understand where the problem come from...
I have to look at this more closely (waiting for the results of the robotic contest).
Arduino Energy Logger
06/04/2018 at 14:02 • 0 comments![]()
I'm currently building an Arduino Energy logger.
It's made with what i have on hand :- Arduino Nano
- INA219 Current Sensor (actually with an 0,1 Ohm resistor, i need to change that if i whant mesaure micro or nano ampere)
- RTC module
- SD card breakout (bottom side)
- 128x32 Oled Display
- 18650 Lipo battery + lipo charger module + 5V boost converter
It will be useful for measering power and energy that i can harvest from a potato...
Motor Driver Board
06/04/2018 at 13:59 • 0 commentsI'm just finished the I2C motor driver board.
There is :
- 2x DRV8839 dual half-bridge driver (it can drive 2 motor in both direction, or 4 in single direction)
- 2x INA180 Current Sensor (1 for each driver)
- 4 sensor input (analog, or digital with a LM339 Quad comparator)
- Atmega168 or 328P (for I2C interface, Speed Control and monitoring)
It's perfboard/breadboard compatible (except for ICSP and UART programming connector).
Energy Harvesting Module
04/20/2018 at 21:03 • 0 commentsHere is a 3D model (kicad 3D view) of the Energy harvesting module.
It is based on a BQ25504 Energy Harvester (with MPPT and Battery management), pair with TPS63030 Buck/Boost Converter. It's perfboard/breadboard compatible.
There is also a 1V precision voltage reference.
You can adjust the parameters (Under & Over voltage protection, Output voltage...) by changing the value of some resistors.
I also made a breakout board for BCAP0350 E270 T13 Supercap (350F, 2,7V).
It's also perfboard/breadboard compatible, but you can use M3 Mounting Hole as terminals if you want (for high current).![]()
There will be more details (explanation and schematic) on the main project page.
I still have to do the other modules (I2C motor driver, sensors...) before I can order PCBs and components (and wait for my salary).
I also have to open a GitHub repository to share files and documentation, but I have never used it ... -
Somes calculations = autonomy of +60 minutes
03/27/2018 at 11:09 • 0 commentsI juste made some simples calcultation to find out if it's possible to power the robot with potatoes energy.
The energy is harvested from a single potato in two super capacitor (2.7V / 350F).
If i place the two capacitor in series, it gives me a single capacitor of 5.4V / 175F.
The energy inside capacitor is :
I don't want overcharge it, so i will charge at maximum 5V :
To extract maximum energy from capacitor, i need a boost converter. Because of the energy harvesting IC, i can't discharge over 2.2V :
I can store and use 2187.5 - 423.5 = 1764 J (0.49 Wh)
At 3.3V, my two motors use each 25mA (light load). (3.3V * 25mA = 82.5 mW)
The electronics (µC, sensors... ) sould use maximum 50mA. (3.3V * 50mA = 165mW)
In total, i need 0.33W. (2 * 82.5mW + 165mW = 330mW)
With 75% efficency boost converter, i should use 0.44W of power from the capacitor.
With a consumption of 0.44W and a capacity of 0.49 Wh, i can power the robot for 1.11 hours (66 minutes, 49 seconds)
If i want know how long i can charge my capacitor with potatoes, i have to measure how much power i can exctract from it...
Edit after some datasheets reading and power consumption measurement of my new tiny motor...
Alexandre LE GALL
