PCB Design
03/20/2016 at 20:30 • 0 commentsWell, As stated earlier, My goal is to design board such a that any DIY PCB etcher can do.
So, I gave special preference to net classes, by making all of them to 1 mm. [thicker traces are best in Iron based toner-transfer method]
I choose DipTrace PCB tool to design the board, It's really an easy tool to work with.
Speaking of placement, I followed K.I.S.S.[Keep it Smart & Simple] rule, and tried well for it.
Placement:
Routing:
Circuit Design
03/20/2016 at 20:20 • 0 commentsLM317 being widely used regulator. It's circuit is straight forward and proven. It didn't take much time to put all the pieces together. And within no time I was ready with Schema.
5mm LEDs at the output end of each LM317, to indicate the ON/working status.
Amar Potdar
