C2-1 gets a face and some touch
07/21/2016 at 23:48 • 0 comments -
07/21/2016 at 23:46 • 0 comments -
hello, this is my workspace
03/22/2016 at 06:51 • 0 comments#zoomer #robot #icybie #mac #python #irobot #bluetooth #bamboo #wifi #sharpie #arduino
nomad + ink
03/22/2016 at 06:40 • 0 comments -
heres some art work
03/22/2016 at 06:35 • 0 comments -
need to figure out how to get constant
03/22/2016 at 02:27 • 0 commentsthere is a note in the .py that makes mention of lack of continuous commands
i don't think you can get steady directional movement via the serial port commanding create2 with keys
i need to do more research, if anyone has been able to modify this please contact
connection successful!
03/22/2016 at 01:09 • 0 comments -
sleepy, but determined!
03/19/2016 at 15:35 • 0 commentslast night i was able to (after many hours of searching" power the robot on with a key command using SERIAL,
i haven't had any luck with python, and I'm not sure if jade or turtle bot will work with my mac. I'm exhausted but i figure ill put in a few hours of study. yay for the self educated!
i realize there is a lot i still need to learn about basic code, and unfortunately i haven't been able to find a good source of educational code resources online.
please share any recommendations! basically i would like to learn how to drive a tethered robot using python and a mac computer with a serial to usb cable. so far I've only had any luck using a program called SERIAL which does not need additional drivers.
I'm actually quite stumped with python at this moment.
unboxing
03/19/2016 at 05:06 • 0 commentsunboxed and docked for a full charge
