Hi, I'm also planning to build a vacuum table for my CNC router but probably out of high density MDF due to budget. Do you have dimensions or drawings? More specifically I was looking for dimensions of the channels and the size of gasket tubing (are you using EDPM cord?). Thanks for sharing!
Yes certainly I used a 3mm channel and a 3mm gasket which turned out to be best. I tried it also with a 2mm and 4mm as it compresses but the 3mm was perfect. I know people have had mixed results with MDF but I would recommend saving up and doing it with a high grade aluminium such as C250. We could also make you one out of MDF if that's easier, but I'll hapilly draw you something up if you need it.
:-( In Youtube from Germany: "Unfortunately, this video is not available in your country because it could contain music from UMG, for which we could not agree on conditions of use with GEMA."
Nice Project,
but whats the actual dimension of the slots?
