1Step 1
Cut off the plug end of the Belkin RG. Solder and shrink wrap the female car lighter adapter. The output is 5V which will work with the Anker adapter to power the HDMI switch and the Raspberry Pi. This provides a battery backup for the Pi so it can keep its place when you turn off the car, and to prevent corruption of the SD card.
