1Hardware Installation
Connect the 9V battery pack to the +V and GND pins of the RasPiRobot Board V3 (check board documentation for clarification).
Connect the left motors to L pins and the right motors to R pins of the RasPiRobot Board.
Plug the RasPiRobot Board on top of the Raspberry Pi 2.
2Software Installation
- Install Ubuntu Core 16 on the RPi 2 - https://developer.ubuntu.com/core/get-started/raspberry-pi-2-3
- a. Dont connect other boards while doing this.
- b . Sufficient power (2A USB) is required for working with the raspberry pi 2.
- c. Required Libraries -
gcc
,g++
,python
,git
- SSH onto the raspberry pi - ssh @
- a. Need the private key in ubuntu core account, it should not ask for password(the password does not work)
- b. To get apt-get and other applications, run
sudo classic
to get the classic ubuntu environment.
- Install the ROS Kinetic using the generic ARM installation - http://wiki.ros.org/kinetic/Installation/Ubuntu]
- Install the RaspiRobot V3 drivers - https://www.monkmakes.com/rrb3/
cd ~git clone <a target="_blank" rel="noopener noreferrer" href="https://github.com/simonmonk/raspirobotboard3.gitcd">https://github.com/simonmonk/raspirobotboard3.gitcd</a> raspirobotboard3/pythonsudo python <a target="_blank" rel="noopener noreferrer" href="http://setup.py">setup.py</a> install
- Clone this repository and run
catkin_make
in the repository.
