Solder Chip HDC1000 and Resistors/Capacitor
Soldering Humidity Sensor HDC1000 and Resistors/Capacitor to a custom built Temperature Sensor
MyOctopus Smart Home Maker Open Source Components
This is the hand soldering process for soldering the humidity chip HDC1000 and resistors / capacitors to the MyOctopus custom built Temperature sensor board
1. Clean PCB
2. Apply no-clean solder paste
3. Place components
4. Use Reflow Air Heater to dry & set
6. Clean Again around the chip
7. Verify connections
8. Verify i2c response
DIMENSIONS:
Humidity Chip: HDC1000 2.04 mm x 1.59 mm
Resistors / Capacitors: "0201" 0.6 mm × 0.3 mm
Octagonal sensor board 11mm
Available I2C config: 0x40 0x41 0x42 0x43
900-CH-4930-TH-TOP.tsv
tab-separated-values - 32.00 bytes - 03/25/2016 at 18:27
Download
900-CH-4930.tsv
tab-separated-values - 250.00 bytes - 03/25/2016 at 18:27
Download
License.txt
GNU GENERAL PUBLIC LICENSE Version 3, 29 June 2007
plain - 34.32 kB - 03/25/2016 at 18:26
Download
MyOctopus-Sensor_Humidity_Temperature_HDC1000#4930.tsv
tab-separated-values - 3.92 kB - 03/25/2016 at 18:26
Download
hdc1000rev2.brd
PCB
brd - 78.06 kB - 03/25/2016 at 18:26
Download
View all 7 files
  • 1 × HDC1000YPAR SENSOR HUMIDITY 3% 8DSBGA
  • 1 × Custom Board Conne1.25mm Pitch PicoBlade™ Wire-to-Board HeadeMyOctopus Temperature Sensor Board
  • 4 × CRCW020110K0FNED Resistor RES SMD 10K OHM 1% 1/20W 0201 (RESISTOR, European symbol)
  • 1 × C0201KRX5R6BB104 CaHubStock™ Yageo CAP CER 0.1UF 10V X5R 0201 (CAPACITOR, European symbol)pacitors / Ceramic
  • 1
    Step 1
  • 2
    Step 2
    . Clean
    2. Apply soldering paste
    3. Place components
    6. Clean Again
View all instructions
MyOctopus wrote 04/09/2016 at 10:30 point
Hi there Hackaday!  We are new around here, please feel free to leave feedback, tips etc
