SmogWatch - WiFi enabled smog sensor
SmogWatch is a WiFi enabled smog (air quality) meter based on ESP8266 (ESP-12). It also measures temperature, humidity and atmospheric press
Public Chat
The device uses PMS5003 as air quality sensor, DHT22 as humidity sensor and BMP280 as temperature and pressure sensor. It also has ability to upload measurements to remote database. More details and detailed description can be found here: https://blog.sperka.online/en/2019/01/smogwatch-wifi-smog-meter/
  • 1 × ESP-12 module
  • 1 × DHT-22
  • 1 × BMP-280 module
  • 1 × PMS-5003
  • 1 × Some wires and connectors
View all 6 components
