Sorting the bubbles
03/28/2016 at 19:56 • 0 commentsAlthough natively working with 16-bit words (14-bit pairs of instructions or data), CPU7 is also supposed to handle "raw" unformatted data in 8-bit, 16-bit, or 32-bit format. As an example that could be a hardware register, video memory, or anything which is not part of CPU7.
As a small coding exercise to test the flavour of the CPU7 assembler, here is the well known "bubble sort" of an area of unformatted bytes.
'! usage: addr len bubblesort8 :bubblesort8 dup 1 > if `! check if the array is more than one element enter 1 over + `! calculate end=addr+len; stack: beg, end 1 swap dup `! stack: end, beg, addr repeat dup rd8 `! stack: end, beg, addr, [addr] 1 over ++ rd8 `! stack: end, beg, addr, [addr], [addr+1] < if `! stack: end, beg, addr ++ `! addr=addr+1 else dup rd8 `! stack: end, beg, addr, [addr] 1 over ++ rd8 `! stack: end, beg, addr, [addr], [addr+1] 2 over wr8 `! stack: end, beg, addr, [addr] 1 over ++ wr8 `! stack: end, beg, addr drop dup `! addr=beg; stack: end, beg, addr endif dup 3 over < until leave `! clean up the data stack endif drop drop `! remove the input parameters from the data stack ;
