PICT0002.JPGCORAL romanian mainframe - unauthorized copy of USA's PDP (picture 2)JPEG Image - 598.61 kB - 12/06/2016 at 06:09 |
PICT0001.JPGCORAL romanian mainframe - unauthorized copy of USA's PDP (picture 1)JPEG Image - 537.08 kB - 12/06/2016 at 06:05 |
test-normal road.mp3Accelerometer output signal - test on normal roadMPEG Video - 3.25 MB - 06/27/2016 at 20:15 |
dacie_bumps_test1.mp3Accelerometer output signal - test on a bad road - lots of bumpsMPEG Video - 691.95 kB - 06/27/2016 at 20:14 |
baudline-moto-engine.mp3Vibration recorded from motorcycle engine using ADXL335 - see the log https://hackaday.io/project/10579-retro-futuristic-automobile-control-panel/log/40671-artificial-intelligence-based-mechanical-faults-diagnosis-iMPEG Video - 235.01 kB - 06/27/2016 at 10:31 |
comp.tar.gzCan-Bus Redux softwareArduino side - (C) [skaarj] 2016 FreeBSD side: (C) Nick Patavalis, modified by [skaarj]. x-gzip - 22.49 kB - 05/30/2016 at 02:01 |
ceasuri dacie poster.pdfGauge dials, custom-made for Dacia 13xx using Gimp Toolkit.Adobe Portable Document Format - 1.08 MB - 05/30/2016 at 01:12 |
ESP Level Sensor.tar.gzESP8266 wireless ultrasonic level sensor. Or distance measurement sensor. Or ultrasonic radar. Whatever. Just don't be a donkey and keep my name there when you plan to use that piece of software for your project.x-gzip - 10.87 kB - 05/29/2016 at 22:01 |
PICT0318.JPGRovesnik TV setTape drive keypad Two D5-100W oscilloscope CRTs And some batteries for comparing the dimensions JPEG Image - 846.93 kB - 03/29/2016 at 06:02 |
bord dacie concept 1.jpegConcept detail for dash board.By the way - how can I embed pictures in the updating logs? JPEG Image - 957.19 kB - 03/29/2016 at 05:36 |
bord dacie concept 0.jpegDash board conceptDrawn by hand with pencil. Unable to draw this on PC. My computer is something ancient - if you read this post carefully, you guessed - it's a Felix Mainframe. Does not support all those fancy things modern computers do. But it runs FreeBSD Unix. JPEG Image - 1.58 MB - 03/29/2016 at 05:34 |
20160328_094615.jpgGraphical User Interface with Midnight Commander.JPEG Image - 958.03 kB - 03/28/2016 at 08:06 |
20160327_195731.jpgFirst attempt to boot FreeBSD Unix using this display...JPEG Image - 996.30 kB - 03/28/2016 at 08:06 |
20160326_230404.jpgLast version of dash board. The brand is the short form of the author's name ("Vasea"). Above the RPM white gauge there's a lazy horse with someone trying to push it - that's because the engine had a malfunction when I tried to make it run with hydrogen instead of gasoline. At the speed gauge (middle) you can notice three icons in the right side - at 140km/h, 160km/h and 180km/h... warning: don't exceed those speeds with this car. It can easily reach them (when wind is blowing from the back) but it's hard to stop.JPEG Image - 1.03 MB - 03/28/2016 at 08:03 |
20160324_120530.jpgComputer Display with color vacuum tube picture screen - a plexiglass cover gives the retro Sepia effect (removes the blue color)JPEG Image - 1.04 MB - 03/28/2016 at 08:02 |
20160314_135853.jpgCover removed in the right side - see the four modified instrumentsJPEG Image - 976.05 kB - 03/28/2016 at 08:02 |
20160314_154823.jpgOriginal dash board with two more gauges (left side) and illuminated needles (right side)JPEG Image - 1.06 MB - 03/28/2016 at 08:01 |
20160303_191027.jpgview in the dark. I do not know how to adjust the settings of the camera. In reality it looks better than in the picture.JPEG Image - 801.64 kB - 03/28/2016 at 08:00 |
20160303_191001.jpgoriginal dash board with illuminated needles (view in light) and a voltmeter installed. The two lights (green and orange) are for external lights and activation of choke manifold (cold engine start at -20 degree celsius)JPEG Image - 1.10 MB - 03/28/2016 at 07:59 |
20160229_141150.jpgsubminiature vacuum tube preamplifier for the multimedia audio systemJPEG Image - 1.11 MB - 03/28/2016 at 07:58 |
20160117_100416.jpgthat's the motorcycleJPEG Image - 1.51 MB - 03/28/2016 at 07:56 |
PICT0316.JPGDial conversion for my old soviet union sidecar motorcycle made in 1942JPEG Image - 841.15 kB - 03/28/2016 at 07:53 |
PICT0309.JPGBack view - installed instrumentsJPEG Image - 696.61 kB - 03/28/2016 at 07:52 |
PICT0303.JPGFirst attempt in installing the new dials. Not really visible, another attempt required.JPEG Image - 965.29 kB - 03/28/2016 at 07:51 |
PICT0301.JPGAnalog gauges with the new needles.Whatever calibration is needed afterwards, it will be programmed inside the Arduino. JPEG Image - 962.42 kB - 03/28/2016 at 07:50 |
PICT0298.JPGJPEG Image - 875.74 kB - 03/28/2016 at 07:50 |
PICT0293.JPGJPEG Image - 1.34 MB - 03/28/2016 at 07:49 |
PICT0291.JPGJPEG Image - 973.90 kB - 03/28/2016 at 07:48 |
PICT0290.JPGJPEG Image - 690.52 kB - 03/28/2016 at 07:48 |
PICT0288.JPGJPEG Image - 992.66 kB - 03/28/2016 at 07:48 |
PICT0286.JPGJPEG Image - 819.14 kB - 03/28/2016 at 07:47 |
PICT0282.JPGJPEG Image - 786.87 kB - 03/28/2016 at 07:47 |
PICT0280.JPGJPEG Image - 969.92 kB - 03/28/2016 at 07:46 |
PICT0279.JPGJPEG Image - 898.85 kB - 03/28/2016 at 07:45 |
PICT0277.JPGJPEG Image - 940.23 kB - 03/28/2016 at 07:45 |
[skaarj]
