Bus is controlled by driver remotely
New idea of automation which is possible and can be implemented.
Separate rooms for driver should be made in which small cabins with properly installed driver seat including brakes gears etc. Infront of driver there should be screen which will be displaying the front and back view to the driver.
Automation should be done such that when he applied break there , signal will be transferred to the bus controlling mechanism and brakes are applied . Similarly all processes should be controlled remotely.
Advantages
1) As driver has no need to go the place where he is driving the bus for passengers so he can controll the bus while sitting in a place where he is readily available.
2) Number of seats can be increased.
3) Driver should waste less amount of energy comparatively as the person is more exhausted while on running vehicle.
DeepSOIC wrote 04/08/2016 at 20:57 point
As a passenger, I won't take that bus.
Muhammad Bilal wrote 04/08/2016 at 21:00 point
Specify the reason please.
DeepSOIC wrote 04/08/2016 at 21:25 point
I've seen too much of mythbusters with their very common remote control problems.
K.C. Lee wrote 04/08/2016 at 22:52 point
Driver can handle unexpected stuff. e.g. replace tires, bus stuck in a ditch, offer first aid, etc
Are you going to strand your passengers in the middle of nowhere or have them fix the bus?
Having a remote system to backup the real driver is a good idea.
Muhammad Bilal wrote 04/11/2016 at 09:04 point
K.C. Lee Yes you are right . But improvement to system can be done.
That is future of technology we called it as "Automation".
K.C. Lee wrote 04/11/2016 at 09:57 point
Next time do some research as to the responsibility of a drivers or anything you try to remove.
Automation meets liability...  Technology evolves whatever but when you are running a business that involves well being of others, you can't take the legal responsibility away that easily.  Let the insurance company figure out the risk factors if/when technology is ready for it.  The business cost is not just the salary.
There is a different industry that you should look at: Trucking.  Same issues, but much less liabilities and not have to worry about consumer appeals.
Muhammad Bilal wrote 04/08/2016 at 21:32 point
Yes you are right. there are advantages as well as disadvantages.But always keep in mind there is space of improvement in every technology or invention.
Muhammad Bilal wrote 04/11/2016 at 14:02 point
Thanks for your Suggestion KC Lee.
This is in my mind but i just want to share idea that i got .
May be its get mature enough to be implemented practically.
