Looking for a new case
04/10/2017 at 14:24 • 0 commentsWell I have not forgotten this project. It just got cold in my work shed and I had to put it aside for the time being. now its warmer and well I'm back on it. Every thing tested good the last time I checked worked like the other one. I now need a better looking project case for it to go in, or maybe I might repaint the one I have. The brown I picked looked good on the can but after painting it. It kinda looks poo brown and that not what I want in my church playing bells. I will be updating This week with a video of it working now that I'm back working on it I need to make sure that it is running like it should. I will post a pic of the case before I repaint it just to remind me never use that color again. If the paint don't fix what I don't like about it I have a new 3d scanner (kinect V2 and V1) I will scan it and use it to make a better looking box with my 3d printer.
Buttons for the MP3 Trigger
10/17/2016 at 14:19 • 0 commentsI have been meaning to add a video of it working on here but now that I needed the space to work on another project it will have to wait till I get it ready for it to go in the box be before I get it on here.
I did get my buttons wired up this week for the MP3 Trigger selectable music. I used some small proto boards and put the buttons on it then wired the stand off above it. Using a solder short to connect the two I can use the jumper wire from amazon to connect them. I will probably use a bead of hot glue to keep them in-place so they don't move
Up loaded the code :P
09/29/2016 at 19:28 • 0 commentsI know there is a better way of having this sketch, but this is the way that made sense to me wile I was working on it. But this is the code I'm working with. Down load it to a single folder and open the church bell file. This will put all the files in the right tabs in the IDE. It seems to woke farely good I found a way to get the Day Light Savings time worked out to a switch, and I have the MP3 trigger working on serial2 now. If you see any thing that you would change besides the formating of the sketch feel free to let me know. Also I working on a drawing of how every thing is wired so that will be coming soon.
Wired up the Boards
09/26/2016 at 15:14 • 0 commentsWell I stop neglecting this project this weekend. Yeaaaa! I got all the parts that I have received as to-date together. I have wired up most of all the boards that I'm going to use but I was asked to use a small amp to boost the power to my larger amp for some reason when the bells play it is not very loud so I'm going to get me one to test with once I get everything up and working. As you can see in the photos that it is wired and all I am waiting on is power. I will make a diagram once I have tested all the boards separately and then together. To make sure it all works before I post any thing. Pulse it will be easier to understand in stead of my rambling about what went where.
I have been looking for a small power supply to power the Arduino board, mp3 trigger and large amp without the need for a separate power supply for the boards and amp. I think I might have found one in the price/watt range I wanted. We will see.
I will be testing tonight I hope (Smoke test) and see what noise I can make. If all goes well once I get the buttons ordered I will be 3d printing the enclosure in a week or so.
All Files (Arduino and plans ) will be uploaded after testing.
Never ordering parts from China Again!
05/27/2016 at 16:15 • 0 commentsWell remind me never order anything from China again !!! It has taken forever to get them in. On a good note I have more parts coming in and I hope I can get started building/testing the new system next week or even start on it this weekend.
I will start off by using the old code that has been working for the past years on the older system and then make changes and test them as I go along. I would like to add new options like : DST switch, On-board computer to make changes to the code only needing a keyboard and monitor( raspberry pi one), on special days play a song representing that day at Noon, and heck I might even have it play Happy Birthday at noon on my birthday. I dont know; before the only goal was to have it play the bell chimes on the hour and a few slectable bell songs to play when needed but now that Im updating it, I have seen where there is room for improvement.
Once the main parts are in I will start taking pic's and update as often as I can on my progress.
Well
04/17/2016 at 22:57 • 0 commentsWell I was looking for my extra Rpi2 and with some luck I found a arduino 2560 in the box . I don't know why I would have labeled the box Rpi2 and put a arduino in there but I'm another part closer to getting this together. I wonder If the house trolls made a trade. :P
Ordered the first part and might be the hardest part to find
04/09/2016 at 22:56 • 0 commentsJust ordered the MP3 trigger from ebay. I really wanted to get it from Sparkfun but they have it back ordered if I run into any problems i may have to look at the wav trigger as a replacement.
Getting started
04/09/2016 at 19:21 • 0 commentsSo today Im just getting this page up and looking for the components I will need. I have built this before and want to make sure that I get every thing like before but updated. The code for this is already made I will tweak it a little once I get the new one built but for now Im going to post the one that is working on the old one ( no picking on my code it is a little bad but it works and its been working for 7 years.)
