The camera lenses is part of a backflow preventer on a sump pump.
The glass lenses was chiseled off a halogen bulb and superglued.
The LED strip comes only for the preview and photo.
The back has the fan opening, leftover screen from a window was used.
The back door opens to all the magic.
On a small piece of wood is the PiB2. USB wifi, USB stick, and a small keyboard are plugged in.
The bottom of the cabinet has a 6" toilet flange so that it can be mounted on a post.
Here are some pics of it working.
I have a picamera for hardware (I was going to copy your setup). And I like the look of the software you have pictured above, (looks like you wrote it) how do I get that?
