1Step 1
Laser-cut the Invisible frame file out of 1/8 inch clear acrylic.
2Step 2
Assemble body rings onto the spine. This takes two people. Be sure to fully support the spine, and take note to get the body rings in the right order and the right side up.
3Step 3
Add the vertical supports- one short one in front, then the four longer ones on the insides.
4Step 4
Add the chest piece and hook onto supports. Epoxy all joints.
5Step 5
Assemble head and neck. Epoxy these joints as well.
6Step 6
Secure sculpture frame by attaching it to a base or weighing it down with rocks.
7Step 7
For Invisible Version 1, plastic wrap the entire sculpture. For Invisible Version 2, string together in any pattern you desire. Find a tension loose enough for a hand to pass through to the center, but tight enough to create added support to the sculpture.
Kate Reed
