Hackaday.io Hackaday.io
Sign up Log in
Zero Drift Instrumentation Amplifier
The AD8230 is a low drift, differential sampling, precision instrumentation amplifier. Auto-zeroing reduces offset voltage drift.
bil-herdBil Herd
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
6 followers
  • Description
  • Details
  • Files 3
    • View all
  • Components 1
    • View all
  • Logs 0
  • Instructions 1
    • View all
  • Discussion 0
View Gallery
761
0
6
4
Team (1)
  • bil-herdBil Herd
Join this project's team
  • Herdware
  • Schematic
  • Wiring Diagram
  • AD8230 Datasheet
  • Gain Calc Spreadsheet
completed project
hardware
analog instrumentation amplifier
This project was created on 04/21/2016 and last updated 11 years ago.
Description
The AD8230 is a low drift, differential sampling, precision instrumentation amplifier. Auto-zeroing reduces offset voltage drift to less than 50 nV/°C. The AD8230 is well-suited for thermocouple and bridge transducer applications. The AD8230’s high CMR of 110 dB (minimum) rejects line noise in measurements where the sensor is far from the instrumentation.
Two external resistors are used to program the gain. By using matched external resistors, the gain stability of the AD8230 is much higher than instrumentation amplifiers that use a single resistor to set the gain. In addition to allowing users to program the gain between 101 and 1000, users can adjust the output offset voltage.
The gain resistors may be inserted as needed without soldering using the built in Mill-Max insertion terminals or the resistors may be permenantly attached via the solderable turret terminals.
This is an offshoot of one of the Instrumentation Amplifiers I did for Hackaday
Files
AD8230.pdf
AD8230 Datasheet
Adobe Portable Document Format - 421.92 kB - 04/21/2016 at 14:48
Preview
Gain-Calculation-AD8230.xlsx
Gain Calculation Spreadsheet
sheet - 9.64 kB - 04/21/2016 at 14:48
Download
schematic.pdf
Schematic
Adobe Portable Document Format - 22.20 kB - 04/21/2016 at 14:47
Preview
Components
  • 1 × AD8230 Low drift, differential sampling, precision instrumentation amplifier.ICs / Instrumentation Amplifiers
Build Instructions
Collapse
  • 1
    Step 1
    Wiring diagram and gain calculation at http://www.herdware.com/wp-content/uploads/Wiring-Diagram.pdf
View all instructions
Log In/Sign up to comment
Sign up with Github
OR
An ultra-low noise amplifier (named EmoeNAP) capable to measure low-noise LDO/OPA's wide band output noise, and many other applications
Project Owner Contributor
Take a 'NAP' and enjoy a moment of silence
floydfishFloydfish
A small high side current sensing IC with ultra high ICMR range. Measure current with accuracy in differential mode.
Highly Accurate Current Sensing Using CSA220
sagar-001Sagar 001
A small board to protect your speakers from unwanted DC-bias. Two N-channel mosfets are used instead of an expensive relay.
Solid state DC speaker protection.
tijl-schepensTijl Schepens
The MonoMeter is a discrete dual-slope integrating A/D, using a reversed NPN transistor as a stable reference
Reversed transistor makes a discrete voltmeter
nikolaNikola
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Zero Drift Instrumentation Amplifier", please tell us the reason.
Send message
Remove Member
