Another printing test without resin
01/15/2015 at 22:18 • 0 commentsJust fixed some bugs in the software. I think i can do first resin test with the new prototype this weekend.
First Laser Test with new firmware.
01/15/2015 at 15:44 • 0 commentsThe new open exposer firmware supports G-Code now. I also wrote some tools to handle g-code files.
The toolchain works as follows:
1. generate a stl file with your favourite cad software
2. sclice the stl to svg with slic3r
3. use the open-exposer slicer to post process the svg file and generate the g-code file
4. send g-code to open exposer with open exposer sender
All tools are written in python. I implemented a small plugin interface for the post processor. With plugins the post processor can be extended to handle different input file formats. By default it supports svg ( slic3r export).
Here is a small video which shows the exposure process with the new firmware.
New design printed and assembled
12/11/2014 at 08:17 • 2 commentsAfter two weeks of hard work, finally i present you the new version of the open exposer 3D Printer....
New Design
11/21/2014 at 14:17 • 0 commentsI am working on a new printable Open Exposer Design. This is a first rough draft.
New Laser Cut Design
09/17/2014 at 22:15 • 0 commentsToday i worked until the late evening at our local Fablab. I finished the Open Exposer laser cut design. It contains the following components.
- Open Exposer base unit
- PCB Exposer extension
- Bearing extension
This weekend i will be at Kerkrade Mini Maker Faire (NL) .
PCB exposing extension
09/15/2014 at 20:12 • 0 commentsI am working on the pcb extension unit for the Open Exposer project. This is a first rough approach.
I will laser cut the new Open Exposer design and the pcb extension on wednesday. I also designed a bearing extension for the bottom of the Open Exposer project.
Looking for a good stage material.
09/09/2014 at 16:57 • 0 commentsI am just testing some materials. Hope i will find the best solution soon.
This time : copper (again), PVC foam and polycarbonate.
First printer test with vat tilt
09/09/2014 at 16:28 • 1 commentHere are some pictures of the first print test with the new vat tilt mechanism.
I still have problems with the build stage material and stickiness of the prints. I already tried acrylic and a copper plate. Any suggestions?
New stage with magnetic mount.
09/01/2014 at 19:51 • 0 commentsMounting and unmounting the build stage was a time wasting process. So i decided to redesign the stage. I use magnets for mounting now instead of a screw.
Vat tilt mechanism - Servo test.
09/01/2014 at 19:37 • 0 commentsAfter hours of designing and printing new parts... Here is the first test video of the new vat tilt mechanism.
