What is B-Pi?
Has three use mode:
- The first is " Assistant Emergency " by a GSM-GPS module provide your contacts assigned your location and status in case of a dangerous situation or emergency so they can take preventive action.
- The second is" Always protected" by a digital platform you can know the location of your contacts , family and friends having a B-Pi device forming a safety net .
- The third is "Mobility alerts " you can select a contact group so that you are aware of your successful arrival with a text message when you make a move from point A to point B.
B·Pi needs a virtual platform ( Web or app) and the device, both work together to give a satisfactory experience tracking. The track is going to give the device using a module GSM -GPS integrated and always connected to a mobile data network, this will be autonomous, don't need a smartphone to operate, but there the option to connect via Bluetooth to a smartphone to optimize resources. The device will have a low power consumption.
The virtual platform that will be available on PC and mobile APP , this will be administering the device , assigning contacts in case of emergency and the text that they will receive and who will see your location at all times. It will be used to view the routes of your contacts.
Our work schedule.
Be safe, Be care, B·Pi.
Abraham Chavez
Klaus
fabsterdam
Ben Lim
Sumit
The GPS works even in the subway?
