Here are the results of the sanded LED inserted into the ping pong ball.
Gone are any "rings-of-light" from the naked LED, and the "spotting" effects of using the white window masking-spray.
Also, since there is not a coating of chemicals from the spray, the LED is brighter than when the spray was used:
