Initial Construction
07/09/2016 at 02:57 • 0 commentsCut all 2x4's and 4x4's. Here is my cut list:
- 9 ea 2"x4"x33"
- 4 ea 2"x4"x48"
- 4 ea 4"x4" x 22 1/2"
Started assembly. Table is wider than my doors so I have to do assembly in my basement.
Purchasing
07/09/2016 at 02:52 • 0 commentsBought most of the materials required, except the hardware for the sliding tables and the upper test fixture table. Still need to figure out what I'm going to do for the test fixture table, and the hard for the sliding tables. So far I am in about $110.
Scissor Jack Concept and Dimensions
04/27/2016 at 01:03 • 0 commentsWorked on getting basic dimensions in place.![]()
Initial Concept
04/25/2016 at 22:14 • 0 commentsHere is an initial concept of the Test-Stand. The dimensions are based on what seems to be a good work area to me.
David Gitz
