The open hardware DSP platform is a range of small boards that can be plugged together to give you a flexible platform for processing all sorts of audio signals. All board designs and information are released under the TAPR Open Hardware License.
This project is ongoing work and existing hardware designs are being tested and modified as needed.
Design files are hosted on GitHub and there is a website at www.ohdsp.org
Work in progress boards include:
CoreOne - An XMOS 200 DSP and Microcontroller Platform with USB and Ethernet
AmpOne - A Dual TDA7492 or TDA7498 4 Channel Class D Amplifier
AmpTwo - A Dual Stereo Headphone Amplifier
BlueOne - A BC127 Based Bluetooth Board
