FPGATED core v1.8.zip
An additional bugfix release of the TED core.
Fixed: The DMA position counter (called videocounter) reset happened at End Of Screen (line 311 for PAL) which was incorrect. It happens in line 205 now. This has caused an interesting color phenomenon in TED Vibes demos. Now it is fixed.
x-zip-compressed - 16.04 kB - 12/13/2025 at 14:49
Download
FPGATED core v1.7.zip
This file contains the latest improved and bug fixed TED verilog core. A huge improvement was done to eliminate some artifacts in certain demos. (1 pixel color delay eliminated between border and bitmap area, Timer2 counting fixed, $FF06 and $FF07 writes happen now at proper cycle borders)
x-zip-compressed - 15.98 kB - 11/18/2025 at 21:24
Download
FPGATED v1.3.zip
Improved TED core (v1.3). DMA delay is fixed and challenging games like Alpharay, Pets Rescue work now correctly.
Some additional output signals defined for ted module in order to connect chroma/luma generator and real C16/Plus4 bus.
x-zip-compressed - 2.19 MB - 01/13/2021 at 21:27
Download
FPGATED v1.2.zip
Check out the latest bug fixed FPGATED core (ted.v) and a modified C16 system (c16.v). Compatibility is highly increased thus FLI/HFLI pictures are shown correctly!
x-zip-compressed - 2.19 MB - 10/04/2019 at 15:27
Download
FPGATED v1.1.zip
Joystick emulation added on PS2 keyboard numeric keypad.
c16.v and c16_keymatrix.v modules are modified to implement joystick emulation.
F11 selects between joy0 or joy1, numeric keypad directions are joystick directions, numeric 0 key is the fire button.
Zip Archive - 2.00 MB - 08/23/2016 at 20:05
Download
FPGATED v1.0.1.zip
Source files of FPGATED v1.0.1
Minor bug fix on c16.v
Zip Archive - 2.00 MB - 08/08/2016 at 21:52
Download
Papilio TED wing.zip
Eagle schematic and board files for Papilio TED wing
Zip Archive - 103.42 kB - 05/05/2016 at 09:24
Download
