Slider Connection
05/04/2016 at 08:04 • 0 commentsI printed the shaft holes a couple of mm too big so I will add a bit of sugru later, to make them nice and tight.
The Frame
05/04/2016 at 08:01 • 0 commentsthe frame
The Frame
04/29/2016 at 12:02 • 0 commentsI bought a 2 meter long square tube aluminium profile a the local store of 20x20x1.5mm size. I saw it in 4 pieces of 460mm length so with the 20mm corners that I am currently printing, the size of the frame will be 500x500mm.
The Start
04/29/2016 at 11:56 • 0 commentsI dissasambled the 2 flatbed scanners, which I plan on going to use the sliders and the steppermotors from. I think I will skip the belt drive and go for direct drive threaded rod actuators, because it seems more straight forward and can use less precise (less rotation per step) stepper motors.
