Hackaday.io Hackaday.io
Sign up Log in
MX29F1615 programmer
Cheap 16 bit parallel flash programmer with an arduino, two counters CD4040, one shift register 74164
acathla-fabienAcathla (Fabien)
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.3k views
4 comments
11 followers
  • Description
  • Details
  • Files 6
    • View all
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 4
View Gallery
2.3k
4
11
8
Team (1)
  • acathla-fabienAcathla (Fabien)
Join this project's team
  • Upverter schematics
completed project
hardware
arduino amiga
This project was created on 04/03/2018 and last updated 6 years ago.
Description
I needed to program those kind of ROM the cheapest way. I bought ten MX29F1615 online (clearly second hand even if not specified) for 14,20€. It can replace a kickstart ROM on an Amiga classic. Then I developed the programmer without buying any expensive component. The PC part is partly based on https://github.com/todbot/arduino-serial for the communication between the arduino and the PC. I tried to use flashrom but failed. It can program the full 16Mb EEPROM in 15 or 20 min. It's slow but it works and I usually program only the half. It's using counters to generate the 21 lines of address (in 8 bit mode), only 128 bytes of buffer are programmed at a time. Code can probably can be improved a bit. The most complicated part was to understand the datasheet. Like the 8bit/16bit modes. You can't program the device in 8 bit mode, but it's not clearly written somewhere.
Files
eeprom_programmer.h
Arduino part
x-chdr - 545.00 bytes - 04/03/2018 at 12:53
Download
eeprom_programmer.ino
Arduino part
ino - 9.31 kB - 04/03/2018 at 12:53
Download
Makefile
makefile - 1.06 kB - 04/03/2018 at 12:53
Download
eeprom_programmer.c
x-csrc - 9.72 kB - 04/03/2018 at 12:53
Download
eeprom_programmer-lib.c
x-csrc - 4.01 kB - 04/03/2018 at 12:53
Download
View all 6 files
Project Logs
Collapse
  • Upgrade to Arduino Mega
    Acathla (Fabien) • 08/31/2020 at 15:54 • 0 comments
    New version using an Arduino Mega (almost no need for external component) : arduino and PC (linux) code with schematics and PCB done with Kicad : https://framagit.org/acathla/eeprom-programmer
View project log
Log In/Sign up to comment
Sign up with Github
OR
happysoul wrote 04/10/2024 at 05:04 • point
https://oshwhub.com/firseve/eeprom_27
Use 74hc595 and Atmega 64Pin like atmega64 128
But ... lazybone
ole00 wrote 02/08/2020 at 22:21 • point
Hi, nice project. Could you please share a schematics with us? It's OK if it's drawn by hand on a piece of paper. I'm interested in seeing how you generated 10V for VHH and the part with the transistor to switch between 5 / 10 V. The software part seems to be clear to me: Address buss is generated via the 2 counters by toggling the 'clock' pin (I like that, it needs just one clock pulse to generate consecutive 12 bit address), the data bus is 16 bit wide in write mode ( top byte of the data bus is generated by the shift register, bottom byte uses 8 arduino pins D2-D9), and for reading only an 8bit data  mode is used where the data bits are again mapped to arduino pins D2-D9 (but this time switched as input). The rest of the code  is just sending and receiving the data between the PC and MCU.
My tips for speed improvement:
1) do not write data with value 0xFF (erased flash memory has already value 0xFF)
2) In flash_databus_output you always set the pinMode for data bits even if you write 128 bytes in one go - optimise it to set the ouput pin mode just once, before the first byte is written.
3) unroll the loops where 8 bits are sent  (the time spent calculating the 'for' loop is eliminated)
4) do not use digitalWrite function - although it is portable, it is also slow because it does several checks and also (if it is not inlined) there is an extra overhead of entering the function, passing the parameters, then exiting the function. Use a macro  that toggles just a single pin on a specific arduino port for maximum speed.
5) use some some sort of data compression (maybe it's an overkill for a simple project like this)
Spark wrote 09/11/2019 at 15:01 • point
Would you share what software you used to program MX29F1615?
Marcelo wrote 05/13/2019 at 02:23 • point
Have you the pcb layout with all components? And how to program all this?
BBC Micro:Bit is not only for kid. Use it as a control board for your applications and program the Arduino way
Project Owner Contributor
Program the Micro:Bit in Arduino C
nicoud-jean-danielnicoud jean-daniel
Using Cortana as the user interface b/w the user and the Arduino enabling opportunities like voice recognition and low budget home automation
Home Automation Using Cortana
nanna56789nanna56789
an alternative Arduino IDE
IDE4Arduino
tobiasTobias
This will emulate the AVR code right out of the .ELF file
Arduino ATmega 328 Emulator
tehaxor69tehaxor69
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "MX29F1615 programmer", please tell us the reason.
Send message
Remove Member
