Top view.
JPEG Image -
3.16 MB -
04/16/2018 at 23:11
Preview
The small model in front. All together Air Pressure Quadcopter. All wires, motors, fans, controls, servos, and battery inside. Unit has been taped up the final will be glued and sealed at tight as possible.
JPEG Image -
2.76 MB -
04/16/2018 at 23:08
Preview
Wiring charging connection will be the only wires showing on the bottom outside of unit. Connecting top duct and wiring together. Close unit up.
JPEG Image -
2.74 MB -
04/16/2018 at 16:59
Preview
Connecting wires together from bottom of unit up. Battery wire Motor wire
JPEG Image -
2.76 MB -
04/16/2018 at 16:56
Preview
Broken down. Prepare for inside wiring.
JPEG Image -
3.05 MB -
04/15/2018 at 19:30
Preview
Top view all together. Two propellers on two off.
JPEG Image -
2.93 MB -
04/15/2018 at 19:29
Preview
Attach propellers. Next work on closing up box.
JPEG Image -
5.18 MB -
04/15/2018 at 16:54
Preview
Apply the spacers to each rod. While setting the fan in the right position.
JPEG Image -
4.40 MB -
04/15/2018 at 16:53
Preview
All four rods set into place.
JPEG Image -
5.47 MB -
04/15/2018 at 16:52
Preview
Tubes connected to fan box. Working on setting the rods next.
JPEG Image -
3.17 MB -
04/15/2018 at 03:35
Preview
Fan box assembled.
JPEG Image -
2.34 MB -
04/15/2018 at 03:34
Preview
Fan box. All pieces.
JPEG Image -
5.36 MB -
04/15/2018 at 03:33
Preview
3d printed fan box.
JPEG Image -
4.13 MB -
04/15/2018 at 03:32
Preview
(Top view) weighs 10.0 oz
JPEG Image -
3.65 MB -
04/12/2018 at 15:56
Preview
(All together)Front view no wires attached. Built up Just to get a good look. All wires will be inside unit.
JPEG Image -
2.13 MB -
04/12/2018 at 15:27
Preview
Installed Control Module inside top duct vent.
JPEG Image -
2.84 MB -
04/12/2018 at 15:26
Preview
Attached motors to ducts.
JPEG Image -
2.44 MB -
04/12/2018 at 15:25
Preview
3d printed fan attached to motor.
JPEG Image -
3.12 MB -
04/12/2018 at 15:23
Preview
(Side View)
JPEG Image -
2.73 MB -
04/10/2018 at 14:43
Preview
(Front View) 3d printed and attached arm supports to unit. Also attached tubes to see how it looks.
JPEG Image -
3.37 MB -
04/10/2018 at 14:40
Preview
So far 6.8 oz.. unit together.
JPEG Image -
2.72 MB -
04/09/2018 at 17:49
Preview
Looks like motion design fits.
JPEG Image -
2.98 MB -
04/09/2018 at 17:39
Preview
Air Pressure Quadcopter Unit.
JPEG Image -
2.63 MB -
04/09/2018 at 17:30
Preview
Motion installed inside Air Distributor Duct.
JPEG Image -
2.18 MB -
04/09/2018 at 17:10
Preview
Motion (Forward/Backwards Left/Right) 3d printed and connected to Servos.
JPEG Image -
3.54 MB -
04/09/2018 at 17:08
Preview
This is how the Air Pressure Quadcopter Unit looks together. (Rubber band is just to hold together)
JPEG Image -
3.12 MB -
04/09/2018 at 14:10
Preview
This is a picture of the 3d printed Air Pressure Quadcopter Unit spread out across top. Motion controls also printed. Along bottom motors, servos, battery, control module, tubes
JPEG Image -
5.09 MB -
04/09/2018 at 14:05
Preview
3D printing Top Duct Vent System
JPEG Image -
2.86 MB -
04/08/2018 at 01:52
Preview
Middle Duct finished.
JPEG Image -
2.58 MB -
04/08/2018 at 01:51
Preview
3D Print Middle Duct
JPEG Image -
2.11 MB -
04/08/2018 at 01:50
Preview
