Wiring unit
04/16/2018 at 17:14 • 0 commentsstarted wiring unit from bottom up.
Connected battery wires
Set rechargeable plug on outside
Connected motor wires
Ran both wires up the unit and taped all wires out of fans way.
Connected top motor wires and connected top motor duct to top of unit.
TEST MODE.... connected battery to both motors and fans spin as designed.
(This unit must be sealed tight)
Far from done still work progress to be made.
Thank you for viewing.
Fan box 2
04/15/2018 at 17:03 • 0 commentsinstalled Fan Box.
Input blades
Input rod
Input spacers
Input propeller
Glue on top
Having slight problems and working on solutions.
Nothing that can't be fixed.
Fan Box
04/15/2018 at 03:40 • 0 comments3d printed fan box along with fan.
Assembled all parts and connected tubes.
Next step work on setting rods in place.
Fans
04/12/2018 at 17:06 • 0 commentsAll fans have been printed
Working on blade box design.
Running test on motor fans.
Quadcopter body printed
04/09/2018 at 14:03 • 0 commentsFinished printing quadcopter body.
Printed piece by piece.
Project was not perfect had to patch a few holes with hot glue.
Posting pictures
Next step redesigning box and 3d printing all fans.
Thank you for viewing..
Top Duct 3d print
04/07/2018 at 21:24 • 0 comments3D printing Top Duct Vent.
Middle Duct 3d print
04/07/2018 at 04:02 • 0 commentsMiddle Air Duct Design has been 3d Printed
Minor design flaws have been detected and patched.
04/07/2018 at 01:46 • 0 comments3d printing started on Fri, April 6
Printing Quadcopter Middle system air duct design.
