Progress
06/15/2016 at 23:50 • 0 commentsPower switch added, LED fitted but not wired.
Should concealed button shut down the pi, or hard reset it? Decisions...
First Light
06/13/2016 at 00:35 • 0 commentsGot the majority of the hardware setup and working, still to do is adding the power switch, wiring the reset button and sorting out the bicolour LED.
Actually the power boost LED and Pi activity LED shine through the case with a cool glow, so not sure what to do with the remaining LED. Pi Power as I removed the LED from the power boost to make everything fit?
