GPLv3
05/29/2016 at 23:31 • 0 commentsThis project is now licensed under the GPL v3, see LICENSE in github repo
Created simple python script for keystroke to OSC
05/29/2016 at 23:15 • 0 commentsThrew together a quick script for testing functionality
#! /usr/bin/env python3 """ This converts keyboard input to basic OSC commands for controlling video playback """ import argparse import sys import tty import termios from pythonosc import osc_message_builder from pythonosc import udp_client def getch(): fd = sys.stdin.fileno() old_settings = termios.tcgetattr(fd) try: tty.setraw(fd) ch = sys.stdin.read(1) finally: termios.tcsetattr(fd, termios.TCSADRAIN, old_settings) return ch if __name__ == "__main__": parser = argparse.ArgumentParser() parser.add_argument("--ip", default="127.0.0.1", help="The ip of the OSC server") parser.add_argument("--port", type=int, default=12345, help="The port the OSC server is listening on") args = parser.parse_args() client = udp_client.UDPClient(args.ip, args.port) keymap = { 'p' : "/play", 'n' : "/next", 'b' : "/previous", 'f' : "/faster", 's' : "/slower" } ch = '' while ch != 'q': ch = getch() if ch in keymap: msg = osc_message_builder.OscMessageBuilder(address = "/video"+keymap[ch]) msg = msg.build() client.send(msg) -
Added ideas for basic functionality via OSC
05/29/2016 at 22:38 • 0 commentsOSC addresses
/video/load ,i
/video/play ,i
/video/reverse ,i
/video/speed ,i
Project Goals
05/29/2016 at 21:15 • 0 commentsCreate a human interface device capable of sending OSC commands:
- Functions: Play/Pause, Forward/Reverse, Tap Tempo, Next/Prev, CUE#, etc...
- Output through ethernet, wifi, or usb.
- Could be a python script to capture keystrokes, or a smartphone app, or raspberry pi/arduino/esp8266
Create a server application:
- Functions: Load video files, output RTP
- Possibly Python wrapper for gstreamer
- Stream 640x480 mp4 with sub 50ms latency
- Switch video cues and change playback speed on the fly
Everything could be running on a single computer or distributed across a LAN. For optimal streaming latency probably will need dedicated network, either router or loopback interface.
