Mounting the Switch Module
07/26/2016 at 19:36 • 0 commentsIntro
One might be wondering, how the switch module can fit into a standard switch plate. In our house we are using a model which provide a mounting frame for it. Therefore it's easy to mount everything into this frame. The pictures shows how I have it done. It contains two switch modules with eight buttons.
The boards and frames are fixed hot glue.
The switch plates are a little modified on the back to fit it into the system.
Front View
On the upper half shows a complete systems. On the lower half the switch plates are left for better look onto the frame. It can be seen that the switch plates are clipped into a frame.
Back View
The back view shows how flat everything fits into the cover. It is possible to mount it directly onto the wall with a small hole for the bus wires.
If there is a flush socket than it's possible to mount additional a relay module under the switch.
Test Setup
06/25/2016 at 17:03 • 0 commentsHere is my test setup for programming. As the configurator is not ready yet, the setup for each node has to be hard coded.
The three relay modules will be mounted in our bathroom, to control the lights and the fan. Additional two of the switch modules will also be mounted for the control of everything.
New Samples made
06/13/2016 at 17:14 • 0 commentsThe system at home still growing: Some more nodes ready to build in.
