Can blue LED light kill bacteria in human milk?
This open lab notebook will investigate the use of blue LED light (400-480nm) for the non thermal pasteurisation of donor human milk
Donor human milk banks collect, store and process donated human milk for use when required. Currently, there are two accepted 'types' of human milk banking. In the developed world where infant mortality is low - the focus of donor human milk banking is in NICU. Donor milk is provided as an alternative to artificial formula where it has been shown to reduce the risk of Necrotising Enterocolitis (NEC - essentially a 'gangrene of the gut' - absolutely catastrophic to a preterm infant). In the developing world there are no safe alternatives to breastmilk feeding, donor milk plays a broader public health role. Currently milk banks use thermal methods to pasteurise donor milk to reduce bacterial content and potential viral pathogens. This does significant damage to bioactive milk proteins that support the immune system. Louis Pasteur came up with this concept in 1860's - surely its time to try something different? So this is an idea I had yesterday...
In 2005 I established and now manage the first donor human milk bank in Western Australia at one of the largest NICU's in the Southern Hemisphere (130 beds). We routinely provide donated breast milk to extremely preterm infants in NICU where there is insufficient volume of a mothers own breast milk. To ensure safety, donors are screened by blood test and questionnaire (like blood donors) but milk is also pasteurised (heated to 62.5C and held for 30mins). This has been shown to inactivate viruses (such as HIV and CMV) and kill bacteria that may present a risk to a vulnerable preterm infants. This is achieved by the denaturation of protein (occurs above about 55C) - many proteins have a biological function and this is usually dictated by their 3 dimensional structure. Simplistically, heat changes this structure and hence the biological function. Do enough protein damage and we can kill bacteria and viruses. However, human milk is an immensely complex biological fluid, it contains many proteins (we've identified over 415 by proteomic analysis) that have a biological function. Many have an immunological function (such as immunoglobulins like sIgA) and others a bacteriocidal or bacteriostatic role such as lysozyme and lactoferrin. These 3 proteins actually comprise about 40% of the total protein content in human milk and are likely to be of physiological significance to the developing immune system of the newborn human infant. As you would expect, heat also damages these proteins and impairs their function. After thermal pasteurisation we do retain some of these proteins but they are greatly reduced. The literature varies but we have seen retention of about 75% sIgA, and 40-50% lactoferrin and lysozyme after thermal pasteurisation at 62.5C for 30 minutes.
We have previously published some initial investigations of alternative 'pasteurisation' methods. There are many alternatives used by the food industry (HTST thermal treatments, pulsed electric fields, high hydrostatic pressure, ultrasonic homogenisation, gamma irradiation) but most are optimised for retention of flavour and taste not necessarily biological function of proteins. In addition most involve protein damage as the underlying mechanism of pathogen reduction, or are unavoidably associated with thermal damage. Our previous work (linked above) examined the use of UV-C light. At 254nm, UV-C light is (again simplistically) absorbed by DNA (specific amino acids in the DNA) and this causes sufficient DNA damage to inactivate (prevent replication - and may indeed kill the organism) bacterial cells. UV-C is a promising method but with IP restricting development, further validation of this method may stall. In addition there are drawbacks to UV-C. Bacteria may be inactivated, so they can no longer replicate and cause catastrophic infection if fed to an immuno-compromised infant but if still physiologically active there is a potential that a toxigenic bacteria could still produce toxin that causes a detrimental inflammatory response in the infant - these types of bacteria do occur in human milk. {NB. A related risk with all of these pathogen reduction steps is that bacteria that produce endotoxins (contained within the bacterial cell) may release these at cell death}. Many bacteria and viruses have sophisticated DNA repair mechanisms so there is also a possibility of re-activation of these organisms over time post treatment. UV-C also reacts with water to produce reactive oxygen species (ROS) due to the photolysis of water - products like hydrogen peroxide that cause oxidative damage to protein - this may cause general damage to protein like we see with thermal methods. Probably much less damage - but certainly needs to be well described before any consideration of the use of these methods therapeutically.
So a couple of days ago I came across a recent research paper (abstract available here) examining the effect of blue LED light on the inactivation of E.coli in bovine milk. The authors...
  • 25 × Super Bright Blue LED 5mm 465 nm wavelength 3.2-3.8V Forward Voltage, at 20mA
View all 3 project logs
Rich text editor
Josh Starnes wrote 07/08/2020 at 00:41 point
You need to get as close to 254nm as you can to kill bacteria, either a mercury vapor bulb or UV LED but try not to go over 275nm or they become ineffective.
Rodrigo Loza wrote 07/10/2016 at 20:01 point
Hello, UV light kills or deactivates bacteria. Of course, it depends on the type of bacteria. E.g: Mycobacterium Tuberculosis gets frozen when UV light is applied, thus, stopping its replication process. Now, i believe it is not exactly blue light, you should be differentiating light by its wavelength. UV light is divided in three types that go from 200 nm to 415 nm. If you use a 400 nm light, which most commercial UV lights use, then it should work pretty well killing or deactivating bacteria. If you want to see more info, check my project. I am building a box to collect and store biological samples in remote places. I am using UV light to maintain a safe environment.
Boris van Galvin wrote 06/14/2016 at 07:38 point
Interesting idea, Not that long ago I had a really bad eye infection to the point where I was somewhat worried that I was going to loose my sight. Medication seemed to have little to no effect and a trip to the hospital resulted in some florescent pigment being put in my eyes.
A UV LED was then directed in to my eye in order to highlight any issues.
About 2 hours later the infection started to subside and within days vision started to clear up.
I am prety confident that the light was the reason for the infection being beaten.
