Tentative Specifications:
Type | Scanner Camera |
Sensor | AMS (TAOS) TSL1406RS photodiode array, 768x1 px |
Dimensions | 175 x 120 x 130mm (L x W x D, including lens), 175 x 120 x 74mm (without lens) |
Image size | 1024 x 768 px (65mm x 48mm physical image) |
Image format | 16-bit grayscale PGM (portable gray map), 48-bit color PPM |
Power | 3.7v Lithium Polymer cell, 850 mAh |
Integration time | 1/15000 - 1/10 seconds |
Lens | Mamiya-Sekor 645 80mm f/2.8 N |
Display | 1.8" Color TFT, 160 x 128 px |
Weight | Approx. 1 kg |
Please tell me you’re hosting the code for this somewhere, you’re blowing my mind!
